Check Re-Calls & Service History Here
#632
VEHICLE INFORMATION
Merchandising Model : TK15543 -2006 SIERRA 1500 4WD CREW CAB SLE2 Warranty Start Date : 01/08/2007
BARS Order Type : 70 - RETAIL - STOCK
Delivering Dealer : ROWAN PONTIAC-GMC
15800 EUREKA ROAD
SOUTHGATE , MI 48195-2658
(734) 282-1010
Selling Source : 48 - GMC TRUCK
Site Code : 26583
Business Associate Code : 115914
Service Contract : No Branded Title : No Warranty Block : No PDI Status : Paid
REQUIRED FIELD ACTIONS
Vehicle Has No Current Record Of Outstanding Campaigns
SERVICE INFORMATIONAL ITEMS
Vehicle Has No Current Record Of Outstanding Service Information
ON STAR AND XM SATELLITE RADIO INFORMATION
OnStar Equipped Yes OnStar Status Inactive Refer to Help page for details or:go to OnStar Online Enrollment (located on the "OnStar" tab in GM InfoNET) or (888)ONSTAR1 (888) 667-8271.
XM Equipped Yes XM Radio ID LEGUD0HK XM Status Inactive Refer to Help page for details or: www.xmradio.gm.ca or Dealer Hotline 1.877.GET.XMST (1-877-438-9677).
APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
36/36000 BUMPER TO BUMPER LIMITED WARRANTY 01/08/2007 249 miles 01/08/2010 36249 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 01/08/2007 249 miles 01/08/2013 100249 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 01/08/2007 249 miles 01/08/2015 80249 miles
36/36000 FEDERAL EMISSION 01/08/2007 249 miles 01/08/2010 36249 miles
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
03/18/2008 249554 # L2020 - HANGER AND/OR CLAMP, EXHAUST SYSTEM - REPLACE 19178 miles
03/10/2008 249287 # E7700 - SHAFT, STEERING INTERMEDIATE - REPLACE 18950 miles
03/10/2008 249287 # K7121 - PUMP, TRANSMISSION OIL - R&R OR REPLACE 18950 miles
03/10/2008 249287 # Z5000 - DEALER/RETAILER TRADE(PART OBTAINED LOCALLY) 18950 miles
03/10/2008 249287 # C3321 - ARMREST, FRONT DOOR - LEFT - R&R OR REPLACE 18950 miles
03/10/2008 249287 # Z7902 - 2-DAY COURTESY TRANSPORTATION 18950 miles
01/02/2008 247282 # Z7410 - GOODWILL OIL CHANGE 16682 miles
07/26/2007 241334 # N6632 - VEHICLE ENTERTAINMENT WIRING AND/OR CONNECTOR REPAIR OR RE 9261 miles
05/23/2007 238475 # E2020 - WHEEL ALIGNMENT MEASUREMENT 5802 miles
01/25/2007 233347 # E2020 - WHEEL ALIGNMENT MEASUREMENT 1067 miles
12/15/2005 A50600 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
#633
recalls on a 2008 gmc sierra C1500 5.3
vin# 3GTEC13098G105951
No re-calls but you got 3 open Service Bulletins you need to have looked at!
VEHICLE INFORMATION
Merchandising Model : TC10543 -2008 SIERRA 1500 2WD CREW CAB SLE2 Warranty Start Date : 09/27/2007
Delivering Dealer : DAVID TAYLOR CADILLAC/BUICK
PO BOX 36428
HOUSTON , TX 77236-6428
(713) 777-7151
Site Code : 09222
Business Associate Code : 210221
Type Number Description Posted Date Status
EI 07082 POWER STEERING FLUID LEAK AT GEAR/RACK, REF-TSB 07-02-32-002D 06/13/2008 See Bulletin
EI 08184 PAINT APPEARANCE, DIRT, ORANGE-PEEL, THIN, RUNS - REF TSB 08-08-51-004 05/20/2008 See Bulletin
EI 08347 FUEL GAUGE INACCURATELY READS EMPTY, LOW FUEL LIGHT ON - REF TSB 08-08-49-016 10/03/2008 See Bulletin
XM Equipped Yes XM Radio ID 2QJYU04K XM Status Inactive Refer to Help page for details or: www.xmradio.gm.ca or Dealer Hotline 1.877.GET.XMST (1-877-438-9677).
36/36000 BUMPER TO BUMPER LIMITED WARRANTY 09/27/2007 0 miles 09/27/2010 36000 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 09/27/2007 0 miles 09/27/2013 100000 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 09/27/2007 0 miles 09/27/2015 80000 miles
60/100000 POWERTRAIN COVERAGE LIMITED WARRANTY 09/27/2007 0 miles 09/27/2012 100000 miles
36/36000 FEDERAL EMISSION 09/27/2007 0 miles 09/27/2010 36000 miles
CLAIM HISTORY
08/26/2008 074659 # K5364 - TRANSMISSION CONTROL MODULE TRANSMISSION REPROGRAMMING WIT 17514 miles
08/26/2008 074659 # J6354 - POWERTRAIN CONTROL MODULE ENGINE REPROGRAMMING WITH SPS 17514 miles
07/23/2007 A05951 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME
#634
VEHICLE BUILD
Merchandising Model : CK15753 -2002 SILVERADO LT 1500 4WD EXT CAB
Gross Vehicle Weight Rating : 2906 kg (6408 lb) Order Number : DXXXJ0
Build Date : 03/14/2002 Build Plant : 12E53
GMVIS is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
OPTION CODES
AG1 - SIX-WAY POWER DRIVER SEAT AG2 - 6-WAY POWER DRIVER & PASS SEATS
AJ1 - DEEP TINTED GLASS AM7 - FOLDING REAR SEAT
AN3 - FRONT BUCKETS WITH POWER ADJ. AU0 - KEYLESS REMOTE DOOR LOCK AND TRUNK OPENER
AU3 - POWER DOOR LOCK SYSTEM A31 - POWER WINDOWS
B30 - WHEELHOUSING & FLOOR CARPETING B32 - FRONT COLOR-KEYED FLOOR MATS
B33 - REAR COLOR KEYED FLOOR MATS B85 - BRIGHT BODY SIDE MOLDINGS
C49 - ELECTRIC REAR WINDOW DEFOGGER C60 - AIR CONDITIONING WITH AIR FILTRATION SYSTEM
C7H - 6,400 LB GVW RATING DF5 - INT R/V MIRROR, LIGHT SENSITIVE W/OUTSIDE TEMP & COMPASS
DK6 - OVERHEAD CONSOLE DL8 - OSRV DUAL POWER HEATED MIRRORS
D07 - CUSTOM FRONT FLOOR CONSOLE EVA - EVAP EMISSION REQUIREMENT
E63 - FLEETSIDE BODY FE9 - FEDERAL/NY/MA/ME/VT EMISSIONS
FK2 - TORSION BAR SPRING ADJUSTMENT FK3 - TORSION BAR SPRING ADJUSTMENT
GMC - ASSEMBLY PLANT-PONTIAC EAST GT4 - REAR AXLE - 3.73 RATIO
G80 - LOCKING DIFFERENTIAL-REAR AXLE JC5 - 4 WHEEL POWER DISC BRAKES
KNP - HD AUX TRANSMISSION COOLING SYS K34 - CRUISE CONTROL
K47 - HIGH CAPACITY AIR CLEANER K68 - 105 AMP DELCOTRON GENERATOR
LM7 - VORTEC 5300 V8 SFI GAS ENGINE M30 - 4-SPD AUTOMATIC TRANSMISSION WITH TOW HAUL MODE
NF2 - FEDERAL EMISSION SYSTEM NP5 - LEATHER WRAPPED STEERING WHEEL
NP8 - AUTOTRAC ACTIVE TRANSFER CASE PCM - ELECTRICAL CONVENIENCE PACKAGE
PDD - COLOR-KEYED CARPET PF9 - CAST ALUMINUM WHEELS
QGD - P265/75R16-114S ALT WOL TIRES SLM - STOCK ORDERS
T96 - FRONT FOG LAMPS UE1 - ONSTAR COMMUNICATIONS SYSTEM INCL 1 YR SAFE & SOUND PLAN
UP0 - AM/FM STEREO W/CASS & CD PLAYER UQ3 - ENHANCED AUDIO SPEAKERS
UY7 - HD 7-LEAD TRAIL. WIRING HARNESS VB3 - CHROME REAR STEP BUMPER
VG3 - FRONT DELUXE CHROMED BUMPER VP6 - NOISE CONTROL
VR4 - WEIGHT DISTRIB. PLATFORM HITCH VXS - COMPLETE VEHICLE LABEL
V22 - DELUXE FRONT APPEARANCE PKG. V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
XGD - P265/75R16-114S ALT WOL TIRES X88 - CHEVROLET CONVERSION
YD3 - BASE EQUIP FOR SCH GVW PL-FT AX YD6 - BASE REAR SPRING
YE9 - SILVERADO YGD - P265/75R16-114S ALT WOL TIRES
ZGD - P265/75R16-114S ALT WOL TIRES ZY1 - SOLID PAINT
Z82 - HEAVY DUTY TRAILERING EQUIPMENT Z85 - HEAVY DUTY SUSPENSION
1SC - LT DECOR INCLUDES: * AIR CONDITIONING WITH AIR FILTRATION SYSTEM * ISRV MIRROR W/COMPASS & TEMP * DUAL PWR HEATED OSRV MIRRORS * REAR WINDOW DEFOGGER * DEEP TINT GLASS * AUTOTRAC ACTIVE TRANSFER CASE * FRONT FOG LAMPS * AM/FM STEREO W/CASSETTE & CD * CHROME GRILLE * ELECTRONIC SPEED CONTROL * POWER LOCKS & WINDOWS * REMOTE KEYLESS ENTRY WITH CONTENT THEFT ALARM * LEATHER WRAPPED STEERING WHL * CAST ALUMINUM WHEELS * BODYSIDE MOLDINGS * 6-WAY POWER HEATED BUCKET SEATS W/FRNT LEATHER SEATING SURFACES & DRIVER MEMORY * ONSTAR COMMUNICATIONS SYSTEM INCL 1YR SAFE & SOUND PLAN 1SZ - EQUIPMENT SAVINGS *MANUAL TRANSMISSION DISCOUNT
12I - GRAPHITE INTERIOR TRIM 122 - GRAPHITE CUSTOM LEATHER TRIM
14U - MED CHARCOAL GRAY METALLIC 6YH - COMPONENT FRT LH COMPUTER SEL
7YH - COMPONENT FRT RH COMPUTER SEL
#636
Yeah the Mr. part was an instant classic!! lol....The heavy duty trailering equpitment basically means that you have a higher grade hitch like a class 4 and that it was already set up from gm to have a trailer brake module, meaning the wires are already run and so forth.
#637
dear mr torque wrench,
lol (i figured it worked for the last guy lol)
any info would be appreciated...
vin# 1GCEC14T65Z264401
#638
Ahhhhh...I can see this Mr. stuff is going to be the ongoing trend huh?....lol..
Well on your particular truck....all'z I got'z to say is....fu*king spotless!!!
VEHICLE INFORMATION
Merchandising Model : CC15703 -2005 SILVERADO 1500 2WD REG CAB Warranty Start Date : 12/05/2005
Delivering Dealer : RELIABLE CHEVROLET
PO BOX 831240
RICHARDSON , TX 75083-1240
(972) 952-1500
Selling Source : 13 - CHEVROLET
Site Code : 07706
Business Associate Code : 112311
Vehicle Has No Associated On Star or XM Radio Information.
36/36000 BUMPER TO BUMPER LIMITED WARRANTY 12/05/2005 218 miles 12/05/2008 36218 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 12/05/2005 218 miles 12/05/2011 100218 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 12/05/2005 218 miles 12/05/2013 80218 miles
36/36000 FEDERAL EMISSION 12/05/2005 218 miles 12/05/2008 36218 miles
CLAIM HISTORY
04/25/2005 A64401 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME
#640
INVOICE INFORMATION
Invoice Date : 04/25/2005
Site Address : RELIABLE CHEVROLET
PO BOX 831240
(972) 952-1500 Selling Source : 13 - CHEVROLET
Site Code : 07706
SHIP-TO INFORMATION
Ship-To Date : N/A
Site Address : REGENCY VANS
2800 GOLDEN TRIANGLE BLVD
FORT WORTH , TX 76177-7016
(817) 847-7171 Selling Source : 13 - CHEVROLET
Site Code : 59660
Business Associate Code : 132250
