Check Re-Calls & Service History Here
#741
The stuff you quoted????? You asked if it would have factory information. That's what is most confusing.
No there's no re-calls.
Now what is the question you are asking me? I'm not for sure what you're asking, now.
#742
Hey man, you're seriously confusing me. It says, you are covered under the GM Bumper To Bumper Warranty up till 36015 miles. It's not saying that you have that many miles on it right now.
thanks again
#744
Ohter than that you look pretty good.
VEHICLE INFORMATION
Merchandising Model : CK15703 -2000 SILVERADO LS 1500 PICKUP Warranty Start Date : 03/17/2001
BARS Order Type : 70 - RETAIL - STOCK
Delivering Dealer : PARKS CHEVROLET, INC.
PO BOX 386
KERNERSVILLE , NC 27285-0386
(336) 992-2000
Selling Source : 13 - CHEVROLET
Site Code : 16551
Business Associate Code : 114002
Service Contract : No Branded Title : No Warranty Block : No PDI Status : Paid
REQUIRED FIELD ACTIONS
Type Number Description Posted Date Status
RC 00024 FRONT BRAKE HOSE ABRASION N/A Closed
RC 00093 FRONT BRAKE PIPE CONTACT WITH BODY CROSS SILL N/A Closed
RC 02029 AIR BAG SENSING DIAGNOSTIC MODULE (SDM) N/A Closed
RC 04007 TAILGATE SUPPORT CABLE 09/18/2004 Open
RC 05068 FRONT WHEEL SPEED SENSOR CORROSION 02/02/2006 Open
SERVICE INFORMATIONAL ITEMS
Vehicle Has No Current Record Of Outstanding Service Information
ON STAR AND XM SATELLITE RADIO INFORMATION
Vehicle Has No Associated On Star or XM Radio Information.
APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
36/36000 BUMPER TO BUMPER LIMITED WARRANTY 03/17/2001 225 miles 03/17/2004 36225 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 03/17/2001 225 miles 03/17/2007 100225 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 03/17/2001 225 miles 03/17/2009 80225 miles
36/36000 FEDERAL EMISSION 03/17/2001 225 miles 03/17/2004 36225 miles
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
10/09/2002 098232 # J9995 - CUSTOMER CONCERN NOT DUPLICATED - EMISSIONS 29198 miles
10/09/2002 098232 # V0881 - 02029 REPROGRAM SDM 29198 miles
10/09/2002 098232 # V0486 - 1999-00 CV & GMC C/K 1/2T P/U - INSTALL NOTICE LABEL 29198 miles
06/11/2002 093471 # R0943 - RADIO FRONT SIDE DOOR SPEAKER REPLACEMENT - LEFT SIDE 23473 miles
03/15/2002 090083 # J5490 - THROTTLE BODY ASSEMBLY REPLACEMENT 19651 miles
02/06/2002 309040 # V0609 - INSPECT BRAKE PIPE & INSTALL SPACER CLIP 18245 miles
02/06/2002 309040 # K4162 - FRONT OUTPUT SHAFT SEAL REPLACEMENT 18245 miles
02/06/2002 309040 # N3860 - WINDSHIELD WASHER PUMP REPLACEMENT 18245 miles
10/27/1999 Z95043 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME
#745
Holly **** ***** man
So I can go up to the dealer and get those? hahahha Thats sweet man. I really appreciate it.
Thanks for doin this for every one. Just noticed you are in VA too. What part?
#747
#748
Could you check mine please- 2GCEK19T6Y1270045
Thanks.
Thanks.
You've got an open Recall on the tailgate support cables....get that taken care of. Check out your service history, that thing was in the shop a lot.
By the way.....nice avatar!
VEHICLE INFORMATION
Merchandising Model : CK15753 -2000 SILVERADO LT 1500 PICKUP Warranty Start Date : 04/14/2000
Delivering Dealer : WINDHAM MOTOR CO., INC.
PO BOX 1096
DEMOPOLIS , AL 36732-1096
(334) 289-0370
Site Code : 24052
Business Associate Code : 114372
36/36000 BUMPER TO BUMPER LIMITED WARRANTY 04/14/2000 178 miles 04/14/2003 36178 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 04/14/2000 178 miles 04/14/2006 100178 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 04/14/2000 178 miles 04/14/2008 80178 miles
36/36000 FEDERAL EMISSION 04/14/2000 178 miles 04/14/2003 36178 miles
CLAIM HISTORY
04/01/2003 266919 0 K5228 - SWITCH, PARK/NEUTRAL POSITION - REPLACE 50274 miles
01/28/2003 263541 0 K4410 - TRANSFER CASE ASSEMBLY REPLACEMENT 48320 miles
01/28/2003 263541 0 F1441 - OUTPUT SHAFT SEAL REPLACEMENT - LEFT SIDE 48320 miles
01/28/2003 263541 0 E7700 - SHAFT, STEERING INTERMEDIATE - REPLACE 48320 miles
01/28/2003 263541 0 Z7904 - 4-DAY COURTESY TRANSPORTATION 48320 miles
09/18/2002 256634 # V0881 - 02029 REPROGRAM SDM 46424 miles
10/02/2001 014853 # F0025 - FRONT DRIVE AXLE ACTUATOR REPLACEMENT 35954 miles
10/02/2001 014853 # F0023 - SWITCH, FRONT AXLE ENGAGEMENT - REPLACE 35954 miles
10/02/2001 014853 # V0609 - INSPECT BRAKE PIPE & INSTALL SPACER CLIP 35954 miles
06/14/2001 A91521 # K7000 - TRANSMISSION REPLACEMENT 31689 miles
06/14/2001 A91521 # K5390 - LINES AND/OR FITTINGS, TRANSMISSION OIL COOLER - UPPER - A 31689 miles
06/14/2001 A91521 # Z7901 - 1-DAY COURTESY TRANSPORTATION 31689 miles
03/15/2001 004076 # E2327 - FRONT WHEEL BEARING AND HUB REPLACEMENT - BOTH SIDES 26499 miles
03/15/2001 004076 # J1120 - SEAL, CRANKSHAFT REAR MAIN - REPLACE 26499 miles
03/15/2001 004076 # J0990 - OIL PAN DRAIN PLUG REPLACEMENT 26499 miles
03/15/2001 004076 # Z7903 - 3-DAY COURTESY TRANSPORTATION 26499 miles
03/15/2001 004076 # F2022 - SEAL, PINION SHAFT OIL - FRONT DIFFERENTIAL - REPLACE 26499 miles
02/08/2001 A90168 # F2383 - RING GEAR AND PINION - REAR DIFFERENTIAL - REPLACE 24376 miles
02/08/2001 A90168 # T2020 - TOWING 24376 miles
01/17/2001 A89997 # F1440 - OUTPUT SHAFT SEAL REPLACEMENT - RIGHT SIDE 23222 miles
01/17/2001 A89997 # F2022 - SEAL, PINION SHAFT OIL - FRONT DIFFERENTIAL - REPLACE 23222 miles
03/30/2000 A86763 # B4642 - STRIKER, REAR DOOR LOCK - RIGHT - UPPER - REPLACE 2 miles
01/28/2000 170045 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
#750
13 Second Truck Club
hey torque wrench i need some help here, i have a problem with a buddys dads yukon. His traction control is going nuts and its causing him to almost get in accidents.
his traction control kicks in at very low speeds he took it to the dealer and they said they cant help him B.S. in my opinion. i just want to see if there was a recall of some sort on this problem and they dont want to fix it!
thanks a lot Keith
vin# 3GKFK16Z04G231583
2004 gmc yukon xl
thanks a lot Keith
2004 gmc yukon xl
