Check Re-Calls & Service History Here
#885
nah, i have access to gmglobalconnect and can see everything that was ever done to a vehicle if it was at a delership for service. i can also see what what warranties are on a car, if the satilite radio is active etc etc. tons of info. all i need is a vin. sounds like they are basically the same thing.
#886
Yep, smae place indeed. I've worked for GM for 13 years, so....
#888
2007 Tahoe...1GNFC13J47R154316
here you go. Nothing bad, but you do have a lenghty service history. but it looks like just nickel and dime **** that has been replaced all the time.
VEHICLE INFORMATION
Merchandising Model : CC10706 -2007 TAHOE 2WD LT Warranty Start Date : 05/02/2006
BARS Order Type : 70 - RETAIL - STOCK
Delivering Dealer : DON HEWLETT CHEVROLET BUICK, INC.
PO BOX 799
GEORGETOWN , TX 78627-0799
(512) 681-3000
Selling Source : 13 - CHEVROLET
Site Code : 30143
Business Associate Code : 114811
Service Contract : No Branded Title : No Warranty Block : No PDI Status : Paid
REQUIRED FIELD ACTIONS
Type Number Description Posted Date Status
YT 07033 SERVICE UPDATE - INVENTORY & CUST. VEHS-BATTERY RUNDOWN-*EXP W/BASE WARRANTY* N/A Closed
SERVICE INFORMATIONAL ITEMS
EI 06052 HVAC A/C NOT COOLING - REFER TSB 06-01-39-005 06/06/2006 See Bulletin
EI 07036 WINDSHIELD GLASS STRESS CRACK/DISTORTION. REF. TSB 07-08-48-001. 02/09/2007 See Bulletin
EI 09081 BODY MOUNTED WEATHER STRIP REPLACEMENT (REF. TSB 09-08-64-012) 04/01/2009 See Bulletin
ON STAR AND XM SATELLITE RADIO INFORMATION
OnStar Equipped Yes OnStar Status Active Refer to Help page for details or:go to OnStar Online Enrollment (located on the "OnStar" tab in GM InfoNET) or (888)ONSTAR1 (888) 667-8271.
XM Equipped Yes XM Radio ID CAGCH08V XM Status Active Refer to Help page for details or: www.xmradio.gm.ca or Dealer Hotline 1.877.GET.XMST (1-877-438-9677).
APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
36/36000 BUMPER TO BUMPER LIMITED WARRANTY 05/02/2006 188 miles 05/02/2009 36188 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 05/02/2006 188 miles 05/02/2012 100188 miles
60/100000 POWERTRAIN COVERAGE LIMITED WARRANTY 05/02/2006 188 miles 05/02/2011 100188 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 05/02/2006 188 miles 05/02/2014 80188 miles
36/36000 FEDERAL EMISSION 05/02/2006 188 miles 05/02/2009 36188 miles
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
03/07/2008 316436 B C0710 - GLASS, ENDGATE - REPLACE 36355 miles
02/11/2008 314296 # B4155 - OUTSIDE REARVIEW MIRROR REPLACEMENT - RIGHT SIDE 35358 miles
02/11/2008 314296 # C0710 - GLASS, ENDGATE - REPLACE 35358 miles
02/11/2008 314296 # D1811 - TEMPERATURE VALVE ACTUATOR REPLACEMENT - RIGHT SIDE 35358 miles
02/11/2008 314296 # B5450 - SUPPORT, REAR COMPARTMENT LID AND/OR TAILGATE/LIFTGATE COU 35358 miles
02/11/2008 314296 # E2180 - INSULATOR AND/OR BRACKET, FRONT STABILIZER SHAFT AT FRAME 35358 miles
02/11/2008 314296 # Z5000 - DEALER/RETAILER TRADE(PART OBTAINED LOCALLY) 35358 miles
11/02/2007 306615 # C0331 - STRIP, REAR DOOR WINDOW OUTER SEALING - LEFT - R&R OR REPL 30844 miles
08/28/2007 300673 # R0754 - RADIO RECEIVER-RETURN TO AC/DELCO ESC 27931 miles
08/27/2007 300673 # C7201 - ARMREST AND/OR SUPPORT ASSEMBLY, REAR OR ROW 1 SEAT (INBOA 27931 miles
08/27/2007 300673 # R0760 - RADIO, REMOVE AND REPLACE 27931 miles
08/27/2007 300673 # D0362 - HEATER AND AIR CONDITIONING CONTROL REPLACEMENT 27931 miles
08/27/2007 300673 # C0331 - STRIP, REAR DOOR WINDOW OUTER SEALING - LEFT - R&R OR REPL 27931 miles
08/27/2007 300673 # C0330 - STRIP, REAR DOOR WINDOW OUTER SEALING - RIGHT - R&R OR REP 27931 miles
08/27/2007 300673 # Z7903 - 3-DAY COURTESY TRANSPORTATION 27931 miles
08/27/2007 300673 # Y0152 - 07033 - SERVICE UPDATE - REPROGRAM BCM 27931 miles
05/27/2006 262732 # E0033 - CAP, WHEEL CENTER - REAR - REPLACE 2014 miles
03/16/2006 A54316 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME
#889
#890
Vin check
Got 2 I'm looking at.
first--06 Silverado 2500 1GCHK23D16F257875
Second--06 Sierra 2500 1GTHK29DX6E186236
Thanks in advance
Thanks in advance
