Check Re-Calls & Service History Here
#922
Location: as far away from Koonerville as humanly possible
#923
VEHICLE INFORMATION
Merchandising Model : CK10516 Warranty Start Date : 06/19/1998
BARS Order Type : 70 - RETAIL - STOCK
Delivering Dealer : FRANK PARRA AUTOPLEX, INC.
1000 E AIRPORT FWY
IRVING , TX 75062-4813
(972) 721-4300
Selling Source : 13 - CHEVROLET
Site Code : 07572
Business Associate Code : 112306
Service Contract : No Branded Title : No Warranty Block : No PDI Status : Paid
REQUIRED FIELD ACTIONS
Vehicle Has No Current Record Of Outstanding Campaigns
SERVICE INFORMATIONAL ITEMS
Vehicle Has No Current Record Of Outstanding Service Information
ON STAR AND XM SATELLITE RADIO INFORMATION
Vehicle Has No Associated On Star or XM Radio Information.
APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
36/36000 BUMPER TO BUMPER LIMITED WARRANTY 06/19/1998 18 miles 06/19/2001 36018 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 06/19/1998 18 miles 06/19/2004 100018 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 06/19/1998 18 miles 06/19/2006 80018 miles
36/36000 FEDERAL EMISSION 06/19/1998 18 miles 06/19/2001 36018 miles
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
05/07/2001 376826 # J0680 - TENSIONER, PRIMARY ACCESSORY DRIVE - REPLACE 33078 miles
05/07/2001 376826 # D0362 - HEATER AND AIR CONDITIONING CONTROL REPLACEMENT 33078 miles
05/07/2001 376826 # D4440 - COMPRESSOR ASSEMBLY - REPLACE 33078 miles
05/07/2001 376826 # N0520 - READING LAMP BULB REPLACEMENT 33078 miles
05/07/2001 376826 # K7231 - HOUSING AND DRUM ASSEMBLY, REVERSE INPUT - R&R OR REPLACE 33078 miles
05/07/2001 376826 # C6010 - ADJUSTER ASSEMBLY, FRONT SEAT MANUAL - BUCKET SEAT - PASSE 33078 miles
05/07/2001 376826 # C6560 - CABLE ASSEMBLY, PASSENGER SEAT ADJUSTER OUTER RELEASE (E-Z 33078 miles
10/02/2000 341709 # B6235 - LATCH, BACK DOOR - CENTER - REPLACE 28453 miles
10/02/2000 341709 # C2745 - CUP HOLDER, CONSOLE - FRONT AND/OR REAR - REPLACE 28453 miles
10/02/2000 341709 # R0935 - RADIO SPEAKER - R&R OR RPL. REAR HEADLINER RIGHT. 28453 miles
10/02/2000 341709 # E7690 - SENSOR, STEERING WHEEL ROTATION - REPLACE 28453 miles
10/02/2000 341709 # N3615 - BLADE WIPER RPL 28453 miles
10/02/2000 341709 # E7230 - STEERING COLUMN UPPER TRIM COVER REPLACEMENT 28453 miles
10/02/2000 341709 # N2145 - SWITCH - DOOR WINDOW - LEFT FRONT - REPLACE 28453 miles
09/20/2000 339642 # J0224 - MANIFOLD, LOWER INTAKE 27868 miles
09/20/2000 339642 # J3517 - NIPPLE, HEATER COOLANT FLOW - FRONT - REPLACE 27868 miles
09/20/2000 339642 # J3480 - WATER PUMP REPLACEMENT 27868 miles
09/02/2000 336752 # J4100 - GENERATOR REPLACEMENT 26404 miles
08/23/2000 334952 S J4100 - GENERATOR REPLACEMENT 25350 miles
07/05/2000 326279 # F1007 - UNIVERSAL JOINT, REAR PROPELLER SHAFT - BOTH - REPLACE 23487 miles
07/05/2000 326279 # T2020 - TOWING 23487 miles
07/05/2000 326279 # Z7902 - 2-DAY COURTESY TRANSPORTATION 23487 miles
05/20/2000 318456 # N0110 - BATTERY REPLACEMENT 22711 miles
05/20/2000 318456 # N0120 - BATTERY POSITIVE CABLE REPLACEMENT 22711 miles
05/20/2000 318456 # J3517 - NIPPLE, HEATER COOLANT FLOW - FRONT - REPLACE 22711 miles
05/20/2000 318456 # F2003 - REAR AXLE HOUSING COVER AND GASKET REPLACEMENT 22711 miles
05/20/2000 318456 # F2023 - SEAL, PINION SHAFT OIL - REAR DIFFERENTIAL - REPLACE 22711 miles
05/20/2000 318456 # E3531 - ARM ASSEMBLY, FRONT CONTROL - LOWER - LEFT - REPLACE 22711 miles
03/17/2000 308357 # E7020 - STEERING WHEEL REPLACEMENT 21543 miles
03/17/2000 308357 # C3358 - FRONT SIDE DOOR TRIM PANEL REPLACEMENT - LEFT SIDE 21543 miles
02/18/2000 303736 # N2145 - SWITCH - DOOR WINDOW - LEFT FRONT - REPLACE 20025 miles
02/01/2000 300865 # E7690 - SENSOR, STEERING WHEEL ROTATION - REPLACE 20016 miles
02/01/2000 300865 # E3530 - LOWER CONTROL ARM REPLACEMENT 20016 miles
02/01/2000 300865 # E3347 - CUSHION, FRONT TORSION BAR SUPPORT MEMBER - BOTH - R&R OR 20016 miles
02/01/2000 300865 # H0042 - PADS, DISC BRAKE - FRONT - R&R OR REPLACE 20016 miles
02/01/2000 300865 # B6235 - LATCH, BACK DOOR - CENTER - REPLACE 20016 miles
02/01/2000 300865 # B4032 - HINGE, FRONT DOOR (WELD ON) - BODY SIDE - RIGHT UPPER - RE 20016 miles
02/01/2000 300865 # B4033 - HINGE, FRONT DOOR (WELD ON) - BODY SIDE - LEFT UPPER - REP 20016 miles
10/15/1999 283939 # D2109 - HEATER/AIR DISTRIBUTION CASE, PASSENGER COMPARTMENT (AIR C 17524 miles
10/15/1999 283939 # R4490 - REMOTE CONTROL DOOR LOCK TRANSMITTER REPLACEMENT 17524 miles
08/10/1999 272465 # D3088 - HOSES AND/OR LINES, REFRIGERANT - COMPRESSOR SUCTION AND D 16486 miles
07/19/1999 268489 # C2860 - FRONT FLOOR CONSOLE REPLACEMENT 15153 miles
07/19/1999 268489 # B5880 - ROD AND/OR LATCH, TAILGATE LOCK - R&R OR REPLACE 15153 miles
05/17/1999 257961 # C4860 - LIFTGATE TRIM PANEL REPLACEMENT 10852 miles
05/11/1999 256831 # H0042 - PADS, DISC BRAKE - FRONT - R&R OR REPLACE 10755 miles
05/11/1999 256831 # E5557 - SPRING ASSEMBLY, REAR AUXILIARY - BOTH - REPLACE 10755 miles
05/11/1999 256831 # N2355 - SWITCH - MULTIFUNCTION (INSTRUMENT PANEL) - REPLACE 10755 miles
05/11/1999 256831 # N3214 - FRONT SIDE DOOR LOCK ACTUATOR REPLACEMENT - RIGHT SIDE 10755 miles
05/11/1999 256831 # D1322 - MOTOR AND/OR FAN, BLOWER - R&R OR REPLACE 10755 miles
05/11/1999 256831 # B6234 - REAR DOOR LATCH REPLACEMENT - LOWER 10755 miles
05/11/1999 256831 # D2109 - HEATER/AIR DISTRIBUTION CASE, PASSENGER COMPARTMENT (AIR C 10755 miles
08/11/1998 214519 # E0203 - TIRE AND WHEEL BALANCING - FOUR 6639 miles
08/11/1998 214519 # E2020 - WHEEL ALIGNMENT MEASUREMENT 6639 miles
04/07/1998 A17541 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
#924
Try this one....
VEHICLE INFORMATION
Merchandising Model : CK15903 -2000 SILVERADO 1500 PICKUP Warranty Start Date : 06/28/2000
Delivering Dealer : APPLE CHEVROLET-OLDSMOBILE
PO BOX 728
RIVERHEAD , NY 11901-0728
(631) 727-1100
Site Code : 02179
Business Associate Code : 111271
Type Number Description Posted Date Status
RC 00093 FRONT BRAKE PIPE CONTACT WITH BODY CROSS SILL N/A Closed
RC 04007 TAILGATE SUPPORT CABLE N/A Closed
RC 05068 FRONT WHEEL SPEED SENSOR CORROSION N/A Closed
36/36000 BUMPER TO BUMPER LIMITED WARRANTY 06/28/2000 19 miles 06/28/2003 36019 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 06/28/2000 19 miles 06/28/2006 100019 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 06/28/2000 19 miles 06/28/2008 80019 miles
84/70000 CALIFORNIA SELECT COMPONENT 06/28/2000 19 miles 06/28/2007 70019 miles
36/50000 CALIFORNIA EMISSIONS 06/28/2000 19 miles 06/28/2003 50019 miles
CLAIM HISTORY
11/13/2006 204476 # V1410 - 05068 - INSPECT WHEEL SENSOR (INC. CLEANING) 133799 miles
10/14/2004 184236 # V1242 - 04007 - INSPECT AND REPLACE TAILGATE SUPPORT CABLES INC. H 111786 miles
11/20/2001 158356 # B5800 - ENDGATE HANDLE REPLACEMENT 35884 miles
03/22/2001 153767 # V0609 - INSPECT BRAKE PIPE & INSTALL SPACER CLIP 19807 miles
03/22/2001 153767 # D0362 - HEATER AND AIR CONDITIONING CONTROL REPLACEMENT 19807 miles
03/22/2001 153767 # Z7901 - 1-DAY COURTESY TRANSPORTATION 19807 miles
01/12/2001 152527 # D0362 - HEATER AND AIR CONDITIONING CONTROL REPLACEMENT 14805 miles
05/10/2000 A72154 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
#925
As always, many thanks!!!
#927
VEHICLE INFORMATION
Merchandising Model : TK15543 -2006 SIERRA DENALI 1500 AWD CREW CAB Warranty Start Date : 01/05/2006
Delivering Dealer : BEAMAN BUICK PONTIAC GMC
1525 BROADWAY
NASHVILLE , TN 37203-3121
(615) 251-8400
Selling Source : 48 - GMC TRUCK
Site Code : 53347
Business Associate Code : 116350
OnStar Equipped Yes OnStar Status Inactive Refer to Help page for details or:go to OnStar Online Enrollment (located on the "OnStar" tab in GM InfoNET) or (888)ONSTAR1 (888) 667-8271.
XM Equipped Yes XM Radio ID DHWEG0CQ XM Status Inactive Refer to Help page for details or: www.xmradio.gm.ca or Dealer Hotline 1.877.GET.XMST (1-877-438-9677).
36/36000 BUMPER TO BUMPER LIMITED WARRANTY 01/05/2006 5 miles 01/05/2009 36005 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 01/05/2006 5 miles 01/05/2012 100005 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 01/05/2006 5 miles 01/05/2014 80005 miles
36/36000 FEDERAL EMISSION 01/05/2006 5 miles 01/05/2009 36005 miles
CLAIM HISTORY
12/06/2005 009217 I Z6998 - PDI ADDS 38 miles
11/28/2005 A32984 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME
#929
VEHICLE INFORMATION
Merchandising Model : CC15753 Warranty Start Date : 05/20/1999
Delivering Dealer : DANNY BELYEU CHEVROLET, INC.
PO BOX 8
CARROLLTON , GA 30117-5001
(770) 832-2436
Site Code : 08030
Business Associate Code : 112550
RC 00024 FRONT BRAKE HOSE ABRASION N/A Closed
RC 00045 FRONT SAFETY BELT COMPLIANCE N/A Closed
RC 06019 TAILGATE SUPPORT CABLE REPLACEMENT 04/03/2006 Open
36/36000 BUMPER TO BUMPER LIMITED WARRANTY 05/20/1999 86 miles 05/20/2002 36086 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 05/20/1999 86 miles 05/20/2005 100086 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 05/20/1999 86 miles 05/20/2007 80086 miles
36/36000 FEDERAL EMISSION 05/20/1999 86 miles 05/20/2002 36086 miles
CLAIM HISTORY
05/31/2001 021519 # V0486 - 1999-00 CV & GMC C/K 1/2T P/U - INSTALL NOTICE LABEL 44926 miles
05/31/2001 021519 # V0609 - INSPECT BRAKE PIPE & INSTALL SPACER CLIP 44926 miles
04/05/2001 020589 # V0523 - REPLACE DRIVERS & PASS SEAT BELT RETRACTORS 41321 miles
09/27/1999 122906 # C0183 - FRONT SIDE DOOR WINDOW REGULATOR REPLACEMENT - LEFT SIDE 10340 miles
09/27/1999 122906 # E3907 - SEAT AND/OR INSULATOR, FRONT SPRING (UPPER AND/OR LOWER) - 10340 miles
05/10/1999 A56875 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME
