Color changing LED needles for 99-06 clusters
I have been messing with my '02 Escalade cluster I had bought a while back. Since my Tahoe has been out of commission from the wreck, I've had more time to play around with it. Some of you know I had engineered LEDs under the needles that turned out pretty awesome. Even got the tach and speedo to color change to red in mid sweep! But now, I have found and put together the parts needed for full, on-demand, any color, any time, color changing needles through a phone app. Each needle base has multiple leds which can change color/brightness independently of each other! I have installed it in my '02 cluster and it looks sick! I already pulled my '05 cluster out to play with and looks like it will work/fit just fine in it as well. Maybe easier actually.
Here's a few pics. I'll have more
Needles only. No backlighting
Just an example of some colors
The following 2 users liked this post by MagicianElectrician:
Pennywise67 (04-20-2023),
silentbravo (04-15-2023)
Well... short answer: No. These are special LEDs sprinkled with fairy dust. It would be nice tho. Easier and less wires usually gets my vote 👍🏻
When are you going to figure out the 03-06 cluster swap for us
Actually, I've been thinking about that lately. Both of my Tahoes are at my bothers shop over 3 hrs away so makes it hard right now. Probably soon I'll be able to tinker with an adapter harness. From what I've read online it seems that just repinning the connector wires makes everything work except the fuel and oil pressure (I think it's those that read backwards) and the DIC.
Where is your brother located? You being in Houston means it is possible your brother is only an hour from me depending lol
You are correct that fuel and OP read backwards. You can make them reverse though I can't remember how. The DIC does work but just the normal trip counter.
Pretty cool! So this is for the 99-02 trucks only at the moment?
