Color changing LED needles for 99-06 clusters
Where is your brother located? You being in Houston means it is possible your brother is only an hour from me depending lol
You are correct that fuel and OP read backwards. You can make them reverse though I can't remember how. The DIC does work but just the normal trip counter.
Oh and my brother lives in Katy. I'm out here right now actually
strutaeng (04-23-2023)
You are correct that fuel and OP read backwards. You can make them reverse though I can't remember how. The DIC does work but just the normal trip counter.[/QUOTE]
Ohh ok, now I see then why nobody has made a plug n play harness for this. Because making those 2 gauges read correctly you would have to actually move the tracers around on the board. Flip-flop em. (Someone had mentioned the tracers before) It's not achieved just by repinning. I guess an adapter harness could be made, but with 2 gauges reading backwards and the DIC on "limp mode"... I'd pass on it myself. So basically from what I can tell, this is a situation of sending in your 03+ cluster to have it operated on and sent back with an adapter harness to make it work (with a limp DIC)
Yes I mentioned this in the other thread. Hence why it is so hard.
I don’t really care about the DIC. It should still show messages like low wiper fluid etc.
The guy I had talked to a while back who told me he was making them (haven't heard anything else since then either unfortunately) mentioned needing some ICs for it. Maybe he's found a way to use those to "reverse" the signal for those 2 gauges going into the cluster so it will read correctly. I'll have to dig in more myself to know. It's probably not as simple as I made it sound.
Do you know how to change the DIC or HVAC display color? Such as to white, blue, red etc.
How do those custom cluster guys do it? I’ve seen it pure white and pure red before. Just need to know how it is done so I can figure out how to do the radio.
