Comparison Test: 2007 Half-Ton Pickup Trucks
#21
Bottom line the toyo tranny is much sronger then our 60 and 80es. That being said this why we are slower, why because, GM protects their weak *** trannys with T/M. Im sure toyo has somthing along the same lines just not so drastic as in our trucks, remove T/M and will get all of the under rated 467 FT/LBS of TQ. And also have a better E/T. But I dont know about beating the toyo with just a tune. Few other things are needed.
#22
One thing I noticed is that Yota is running 10.2:1 compression on "87 or higher" fuel for that 5.7. So is this going to be like the escalade motors where they test and publish numbers with the 93 or 91 octane, but then if you run the 87 is detunes it quite a bit? If they are getting those numbers on 87 I'm gonna be damn impressed. Just funny because the escalade at 10:1 compression calls for 89 octane. I just want to know if Yota is that good or if they are slightly misleading (IMO).
Even on the little econo boxes it looks like Honda and Toyota are able to push their static compression ratios higher than GM is able to, yielding equiv power and better gas mileage. Sorry, I'll get off my stump now.
#24
I found a picture on edmunds blogs of the 2007 Tundra Street Concept with the Supercharged 5.7 iForce.
The painted grill looks way better then the stock chrome one...
#25
just found a bunch more here: http://www.autoblog.com/2006/11/01/s...treet-concept/
GM better wake the **** up and gives us a RCSB w/ 6.0 or 6.2!!
If Toyota make this truck at a reasonable price and with a optional AWD it's gonna sell big time!!
#26
Ugh, if that Toyota wasn't so hideous looking I wouldn't feel bad about getting a new Tundra over a VortecMax Silverado. GM is really starting to disappoint me, they need to get more serious about supporting the customers!!!
#29
Originally Posted by GMCtrk
Someone in Detroit needs to pull their head out of their *** and put in a transmission that can handle these engines, not some 1980 350. For the first time, I am truly embarrased for GM trucks.
