Considering selling as a package
Its time to upgrade and make more power so ive been considering selling my current engine minus acc and tb, trans with converter, and rear diff all as a package deal to make someone a 12.0 package
Engine is LS1 with 243's milled .012-.015 and .040 cometics, TSP 228r-112 cam, pushrods from TSP and some .650 lift springs, LS6 sodium valves, pacesetter 1-3/4" LT's, Ported Fast 90 intake, and LS6 injectors, Volant cold air intake with custom ram air for 03+
Trans is stock with shift kit, vette servo, billet OD servo, TCI 9.5" 3600 stall, starting to slip and will need a rebuild
Rear diff is 05 with druns, detroit trutrac, and 4.88's, stock axles
Im just not sure what to ask for it all
Went 12.27 @ 109 letting all the way off the throttle to let the trans shift 2-3 then getting back in it. Easily a 12.0 pass if trans would have done right. DA at the passes we made was 1100-1200
Trans isnt slipping its just not making the 2-3 shift at the track. It works like it should once home on the same drag wheel setup. Not sure whats happening here
JCunningham
03-17-2016 04:48 AM
