Converting from DBW to DBC...
Old 12-05-2013, 11:29 AM
  #21
Custm2500's Rude Friend
1FastBrick's Avatar
Originally Posted by xx_ED_xx
yeah it has numbers now i am hoping the help section give me some insight about that
nope no insight....
Sorry, I am only familiar with EFI Live and a little bit with HPTuners.
In EFI Live you can tell it which platforum you have as well as select which type of throttle body under the options.
Old 12-05-2013, 02:13 PM
  #22
xx_ED_xx's Avatar
Too bad the jet one isnt that intuitive...
May have to break down and spend 600 plus bucks and get me efi live
Old 12-05-2013, 03:05 PM
  #23
1FastBrick's Avatar
I didn't see the ability to do that in HPT.
I could be wrong as I am not as familiar with it.
I have never tried to change it either.
I know if you use a Van Operating system and you have the correct computer it should function.
The Vans had DBC from the factory all the way up to 07 from what I read.
Old 07-20-2017, 11:17 AM
  #24
03sierraslt's Avatar
So who's done this.
Old 07-20-2017, 11:58 AM
  #25
xx_ED_xx's Avatar
Ok I have done this, had to learn myself and lt1swap.com was very helpful as well. As long as your pcm has the IAC driver chip it is a simple switch in system options to turn it on then you add the 7 wires 3 for tps and 4 for iac and good to go. whatever platform your pcm was out of then ETC should be set to 1 if it is DBW then you change it to 0 and tps and iac will work. All my trucks are swaps and all DBC
Old 07-20-2017, 12:23 PM
  #26
I have to locate a pcm. Pretty sure mine doesn't support it. It I have access to some 04 express van ones so one should work. I need to check the service number on mine. I've been reading on lt1swap.
Old 12-18-2019, 08:37 AM
  #27
Marc1970ss's Avatar
Default I am doing a DBC 8.1 in my chevelle. Need advice
what tables in the idle tab need to be changed. I have a tune file from a DBC 5.3. Do I need to copy that data? If so how much of it?
Old 12-18-2019, 08:40 AM
  #28
xx_ED_xx's Avatar
tables should be the same because the air needed for idle is the same
Old 12-18-2019, 08:46 AM
  #29
Marc1970ss's Avatar
The IAC reset position is 0
and the park position airflow table is 0
does this need to be changed?
Old 11-22-2020, 10:16 AM
  #30
Registered User
Arone Awol Storey's Avatar
would I be able to do the sway if I had engine wiring harness for DBC motor and intake and tb and ecm ?
Quick Reply: Converting from DBW to DBC...
