Coolant Smell Sometimes
Isn't the heater core located behind the dash board mounted against the firewall. Generally that is the location and it usually make the carpet in the passengerside of the truck damp if the leak is real bad. I maybe wrong on this since I haven't had this problem in any of my Silverados.
Originally Posted by three83
If you have a pin hole in the heater core you won't loose much coolant and it would give off a slight coolant smell
