Crackling front left
Originally Posted by CHEVRACER83
+1 Hub And Bearing Assembly Probably Ready To Go
NEEDED A NEW HUB AND A NEW HALF SHAFT...SHEERED THE 1/2 SHAFT RIGHT WHERE IT BOLTS TO THE HUB... DID BOTH ON THE SIDE OF THE ROAD WITH SIMPLE HAND TOOLS AND A JACK... SO ITS EASY!!
Originally Posted by 2001si3rr@
Are you changing both hubs?
Originally Posted by joehawkz71
MAKE THAT 2 CASUE I LEARNED THE HARD WAY! MY WHEEL CAVED IN TO THE WHEEL WELL WHILE I WAS DOING 70 DOWN THE RAOD....GOOD THINK I JUST FINISHED GOING AROUND THE CORNER!
Originally Posted by viciousknid
Actually i was just going to change the 1 thats popping. but it wouldn't be a bad idea to change both.
Sure don't..
You could possibly jack each side under the control arm were the spring pocket is. Jack till you clear the tire and try to wriggle the wheel assembly in and out. Put one hand on top of tire and the other on the bottom, wriggle the whole thing in and out. If it moves or pops I'd say it's worn, but not sure if that's a proper way to check them.
Maybe someone who know could chime in.
PT's Slowest Truck
If the hub/bearing is worn badly enough, there will be play if you jack up the front end and grab the top and bottom of the tire and wiggle it that way. Sometimes a bearing will make noise and not have play though, but if it's "popping" I would expect there to be play. FWIW, I had my front shocks replaced twice under warranty for squeak noises, but my truck is a Z71 4x4.
With 75k on the clock, it's probably a good idea to check all of the front end components...ball joints, tie rod ends, sway bar end links, etc.
Originally Posted by dirt_track_racer_81
thats why i like my truck loud so i dont have to worry about all the little noises it makes..haha
I'll mess with it this weekend and see what i find. it don't sound like the suspension tho because it pops with the rotation.
I just hope i change it before it decides to change its self.
