Crackling front left
Old 05-30-2007, 02:32 PM
2001si3rr@'s Avatar
Are you changing both hubs?
Old 05-30-2007, 04:12 PM
joehawkz71's Avatar
Originally Posted by CHEVRACER83
+1 Hub And Bearing Assembly Probably Ready To Go
MAKE THAT 2 CASUE I LEARNED THE HARD WAY! MY WHEEL CAVED IN TO THE WHEEL WELL WHILE I WAS DOING 70 DOWN THE RAOD....GOOD THINK I JUST FINISHED GOING AROUND THE CORNER!
NEEDED A NEW HUB AND A NEW HALF SHAFT...SHEERED THE 1/2 SHAFT RIGHT WHERE IT BOLTS TO THE HUB... DID BOTH ON THE SIDE OF THE ROAD WITH SIMPLE HAND TOOLS AND A JACK... SO ITS EASY!!
Old 05-31-2007, 05:22 AM
Where's the Beef?
viciousknid's Avatar
Actually i was just going to change the 1 thats popping. but it wouldn't be a bad idea to change both.
Did yours get louder and louder over time or did it stay at the slow annoying pop?
Old 05-31-2007, 06:37 AM
2001si3rr@'s Avatar
When I bought my truck it was popping in the right side. I noticed it when I was riding passenger. I told to guy I was buying it from what I heard and we took it straight to the dealership. They found right one worn and replaced it. They said it was fine to just change the one that was worn, but they also inspected the left one for any signs of wear. He paid to have it done before I bought it from him. Good guy.
Old 06-01-2007, 03:12 AM
Where's the Beef?
Know what to look for as far as wear goes?
Old 06-01-2007, 04:42 PM
2001si3rr@'s Avatar
Sure don't..
You could possibly jack each side under the control arm were the spring pocket is. Jack till you clear the tire and try to wriggle the wheel assembly in and out. Put one hand on top of tire and the other on the bottom, wriggle the whole thing in and out. If it moves or pops I'd say it's worn, but not sure if that's a proper way to check them.
Maybe someone who know could chime in.
Old 06-01-2007, 09:30 PM
PT's Slowest Truck
budhayes3's Avatar
If the hub/bearing is worn badly enough, there will be play if you jack up the front end and grab the top and bottom of the tire and wiggle it that way. Sometimes a bearing will make noise and not have play though, but if it's "popping" I would expect there to be play. FWIW, I had my front shocks replaced twice under warranty for squeak noises, but my truck is a Z71 4x4.
With 75k on the clock, it's probably a good idea to check all of the front end components...ball joints, tie rod ends, sway bar end links, etc.
Old 06-01-2007, 09:38 PM
dirt track racer 81's Avatar
thats why i like my truck loud so i dont have to worry about all the little noises it makes..haha
Old 06-02-2007, 03:33 AM
Where's the Beef?
WORD!
I'll mess with it this weekend and see what i find. it don't sound like the suspension tho because it pops with the rotation.
I just hope i change it before it decides to change its self.
Old 06-02-2007, 10:23 AM
PT's Slowest Truck
budhayes3's Avatar
Since it pops with rotation, check the simple stuff also...like a wheel weight hitting the caliper, backing plate hitting the rotor, etc. If all that is good, my first guess would be hub and bearing then. Good luck!
Quick Reply: Crackling front left
