Crate motor here! Got some questions
I picked up the LQ4 crate motor today. Looking over the instructions that came with it, I noticed they said to prelube the engine using Tool # J45299, which looks like a gas can with a hand pump and hose on it. My question is: Is there any good way to McGyver this? I don't really want to buy something like this that I'll only use once, although I will if necessary. If I need one, is there some place where I can get it quick and cheap?
Secondly, the engine is a long-block, and so has no flywheel. I thought I could swap the one from my 4.8 but I read elsewhere that this may not be the case. The 4.8 is a 2003, and the 6.0 is a reman 2005+ which is supposed to mate with the M32 (aka 4L65e) transmission. Anyone know for sure on this?
As always thanks for the help. PS. Did a search w/ no luck.
Many thanks to those who responded. I purchased a gear pump at NAPA which should address the prelubrication issue, and can also be used for other things. As for the flywheel, the true answer will only become known during assembly. If fitment issues arise they should be resolvable by a visit to the local junkyard.
OHsixLS3
08-10-2015 07:19 PM
Nimoryan
07-05-2015 03:50 PM
