Degree a cam? Dot to Dot is just fine he says...
I asked about borrowing a degree wheel to install a cam, He said “Why don’t you just do it dot to dot?”,…as if I was dumb for wanting a degree wheel.. and I said:
Because "Dot to Dot" is the ghetto fabulous way to install a cam. Even 1
or 2 degrees off makes a difference. The wheel is only $20 I already
have the dial indicator. It's not really that hard to do the right way. I
just need to fab up a piston stop.
What do you guys think? Am I being overly cautious?
Originally Posted by Corvette Guy w/heads and cam
It is not ghetto fabulous the only reason you even need to degree a cam
is if its ******* large as hell so you get a good PTV clearance. If it's
a smaller cam degreeing is unnecessary
Wearin' da big hat
If you want every tiny bit of horsepower out of your setup, and want to purchase an adjustable timing gear set then yes degree it. Or if you've got a lot of money tied up in it and want everything perfect, then yes do it.
Either way, it's going to work just fine. If it's worth it to you, degree the cam. I've put many cams in using the "dot to dot" method, and never had any problems. You could even degree a stock cam and see a very small increase in power/efficiency simply because every cam is not ground exactly the same.
Degreeing your cam is the right way to do it. Dot to Dot is a shortcut, which will have a different effect in every situation. Like I said before, dot to dot works, but if you've got the time, knowledge, and $$$ then you should degree the cam.
