Degree a cam? Dot to Dot is just fine he says...
Old 01-09-2011, 10:34 AM
Tootall's Avatar
Originally Posted by 1SlowHoe
It has a ls7 cam sprocket, ls2 chain. You think I need a better one?
those are just fine. . . but it sounded like you wanted a tighter tollerence.
Old 01-09-2011, 10:50 AM
9 Second Club
Rhino79's Avatar
Like Budhayes said, degreeing the cam is only to insure it is what it is supposed to be. With todays machines and computer programs, I have not seen an LS cam that was not ground correctly. Thats why you see a cam that is a 112+4, that has 4 degrees ground in. In the old days they werent adding advance in the grind for the most part, therefore you had to manually advance it to get the optimum setup.
Three6GMC
11-05-2015 10:02 PM
Tig
09-30-2015 07:39 PM
Jake99
08-08-2015 07:56 AM
Blwn99x
08-02-2015 09:51 PM
GreyChevy
07-07-2015 08:57 PM
Quick Reply: Degree a cam? Dot to Dot is just fine he says...
