Designing a braking system
Old 04-14-2016 | 12:59 AM
xEtherealx's Avatar
Default Designing a braking system
I'm trying to put together my braking system geared toward autocross but I don't quite know what to shoot for besides a 70/30 split -- or even if that is desirable for autox?
I've got stock GM calipers front and '97 Camaro calipers rear, and the split can be seen as I've calculated it in the attached shot of my spreadsheet. I'm assuming a coefficient of friction of .3 for OEM pads but that's just a ballpark that I read somewhere.
- How can I find friction coefficients for pads, especially OEM type?
- I get that bore size and pedal ratio are linked, but how do each of these affect pedal feel?
- If I do go OEM on the rears, what material would dissipate heat best?
Old 04-14-2016 | 05:26 PM
xEtherealx's Avatar
Ok so I've been thinking about this plan of attack:
1) Calculate the minimum bore required to move the needed volume of fluid to the calipers -- bore area x stroke
2) Based on the bore from 1) calculate the pedal ratio needed to get a desired psi output from the master.
#2 is sort of tricky, because why would I not want as much psi output as possible and thus the largest ratio that I can get? I understand that I want my pedal to achieve a full MC stroke, and the ratio will affect that ability. Am I shooting for the largest ratio that gives me a full MC stroke?
HEMI450HP
04-15-2016 03:33 PM
someotherguy
04-14-2016 04:59 PM
2KRedSilverado
04-14-2016 08:12 AM
4Runoma
04-11-2016 06:44 PM
Quick Reply: Designing a braking system
