Different size tires front and rear on 4x4
I know 4x4 is a mechanical link between the front and rear so they "should" be turning at the same time. Case in point 275/55/r20 are 31.9" tall and 305/50/20 are 32.0" tall. .1" is still .307% difference ideally. Is that even too much of a risk on 4x4. I'd go 305's all around, but I don't want that much tire on my steering wheels (hydroplaning) and I'm afraid it is going to hurt the steering feel.
opinions?
opinions?
Different size tires is just a bad idea on a 4x4. I don't think you will notice any steering difference with an extra inch of tire. Hydroplaning is more a factor of how well the tread pattern moves water out of the way than the size of tire.
Originally Posted by nightrunner
275/55/20 is only an 10.8 inch wide tire
205/50/R20
28.1 height
8.1 width
4.1 sidewall
275/55/R20
31.9 height
10.8 width
5.9 sidewall
205/50/R20
28.1 height
8.1 width
4.1 sidewall
275/55/R20
31.9 height
10.8 width
5.9 sidewall
32.0 height
12.0 width
6.0 sidewall
IMO, you really need to check the actual installed height of the tires. Manufacturer #s are not perfect. Rim width will play a part too.
Think of 99% of the 4x4 trucks out there with a bit more wear on the rear tires compared to the front, or vice versa. The diameter of the tires is not exactly the same.
You should not be in 4x4 unless there is some loss of traction anyway, allowing some difference in rotation front to back.
Why are you asking?
2001 2wd ecsb 5.3 G80
Originally Posted by Moddoo
Why are you asking?
IMO... a difference that small doesn't really matter unless you are driving around on the freeway or surface streets. Ideally, you aren't in 4wd during this time, so the front wheels are not driven, and thus all will spin at the same speed. Once you go offroad, the surface will probably have some give and running different size tires won't be too big of an issue. Ideally, you will get all same size tires though.
BoostedBowTie
01-03-2020 07:46 PM
Steve-O-08
04-19-2018 10:32 AM
mrgrim
07-08-2015 09:12 AM
