Do headers just plain need to be tighted
Factory bolts, same as you (according to your pics in the other thread)
I don't understand why the plug is in the way. They sit well below where the bolts are located and should not interfere.
Pb blasted header bolts today
PB BLASTED HEADER BOLTS TODAY, LETTING IT SIT OVER NIGHT, IM JUST HOPING WHEN I TAKE THE HEADER OFF THERE WILL BE ENOUGH OF THE BOLT TO GRAB HOLD WITH A VICE GRIP
IM CROSSING MY FINGERS ON THIS ONE
I WAS TOLD TO GET SOME GOOD GRADE 8 BOLTS OR ARP OBVIOUSLY
IM ALSO WONDERING HOW I WILL TORQUE THESE HEADER BOLT BACK {NO ROOM IN THE REAR} I FIGURE GOOD-N- TIGHT SHOULD WORK LOND AS I GET THE CORRECT PATTERN .
ANY THOUGHTS ON THIS
First set proper torque on the bolts in the middle that you can get the torque wrench on, then for the two pesky B 'stards in the back, take a box end wrench (if you have one great, if not go buy one, at least a regular closed end wrench - NO crescent wrenches for crying out loud, you'd have a helluva time getting it to fit back there anyway) and get a feel for the torque set with the torque wrench. Try to duplicate that torque setting with the wrench on the back bolts. Again, like has been said before, Anti-sieze is yo Friend. A little bit of lubricant on the face of the flange will help torque be truer as well.
