Do headers just plain need to be tighted
Old 02-27-2012, 09:18 PM
  #21
black04's Avatar
1/4" ratchet works well for the rears
Old 02-28-2012, 01:37 PM
  #22
40series's Avatar
Default Cant get the rear header bolt loose
Today i attempted to take the dam header off and i could'nt even get the rear bolt off maybe the wheel well should come out the way dont have a clue about that either im pissed the header bolt thats broke is the first one and im figuring if i can get the header at least off i have a shot at grabbing it with some vice grips i took the coolant temp sensor out the way and loosened some bracket near there b ut i just about give up today
Old 02-28-2012, 07:32 PM
  #23
Cknox121's Avatar
Header bolts are supposed to be torqued to 18ft-lbs.
I had one break in the very back on the driver side and left the bitch, 3000 miles and no leaks. Used some hightemp RTV on gaskets and flange, no leaks. Good luck with removing them.
Old 03-05-2012, 06:50 AM
  #24
gagliano7's Avatar
When you put the header bolts back in use antiseize.I used antiseize on my bolts for my 05 Gto torqued to 18 ft lbs and retorqued after a heat cycle and never had to touch them again.
Old 03-05-2012, 07:43 AM
  #25
sprayedenali's Avatar
Why so much caps lock?!?
Old 03-06-2012, 05:07 PM
  #26
40series's Avatar
Default Can you get studs on with engine in ?
Originally Posted by black04
get some header studs
can you get studs on with engine still in ?
Old 03-06-2012, 07:21 PM
  #27
SnakeOiler's Avatar
no different than putting in bolts.
Old 03-06-2012, 07:31 PM
  #28
40series's Avatar
Default That rear drivers side bolt scares me
that rear drivers side bolt scares me - how would you put them in ???
Old 03-07-2012, 07:08 PM
  #29
david8399's Avatar
Header & Exhaust Gaskets - Tech Article - Chevy High Performance Magazine
little article i found a while back while putting headers on my 454ss, may help some.
Go5.3tt06
25
09-04-2016 10:25 AM
Superman09
09-25-2015 05:55 AM
Justin87gn
09-10-2015 12:06 PM
turbo truck
09-02-2015 09:58 PM
Quick Reply: Do headers just plain need to be tighted
