do i really need a trans cooler??
Old 05-09-2010, 11:00 PM
Jeteys5.3's Avatar
I'm def getting the cooler its just going to take a few weeks. And no i don't have the aeroforce to watch anymore
Old 05-09-2010, 11:02 PM
Jeteys5.3's Avatar
Well i had my mind set on the trucool 40k. But i heard B&M coolers are a direct bolt on setup with no modification needed? What B&M cooler is equivalent to the trucool 40K?
Old 05-10-2010, 12:23 AM
Dewey's Avatar
as far as i know, any cooler that's bigger than stock will require custom plumbing. i've been doing a little research into buying one as well.
Old 05-10-2010, 10:05 AM
TXsilverado's Avatar
B&M doesnt make an equivalent cooler last i checked.
Old 05-10-2010, 10:43 AM
Jeteys5.3's Avatar
Gotcha. Maybe ill just delay the install until i can afford a trucool
Old 05-10-2010, 10:46 AM
11 sec. Truck Mod
TIM Z's Avatar
Yep, just wait till you can do it right.
im going to need a tru cool soon too.
One thing at a time!
Old 05-10-2010, 11:55 AM
PT's Slowest Truck
budhayes3's Avatar
I think that the biggest B&M makes is a 24K...I currently have a Permacool 17k tube and fin cooler that I will be replacing with a trucool 40K in a few weeks when I swap in my FLT level7 and Circle-D 258mm converter. You'll probably be fine with the factory cooler but why take a chance, even a 20k cooler will be more efficient than the factory cooler and is easy and cheap enough to do..."protect your investment"....words to live by....
Old 05-10-2010, 04:15 PM
fastnblu's Avatar
Originally Posted by andrew383
You just got the TB convertor rite???
I picked up the brackets from a a member on here just for the 40k...
40k install brackets
Some nice info in there.
Stew is right. Heat can even kill a stock trans, in fact it's the #1 reason for their demise. :nunchuk1: A 278mm reworked TB may be fine, but like others said, it's cheap insurance.
I agree w/. others, even if I considered just throwing in my tranny & stall for a wk. or 2 while I could collect fittings (&/or -AN line if I run it) It's just not worth it tho. I could run the fittings incl. in the TruCool 40k in the meantime.
40K could apply to any co. if they actually offer it. It's a towing capacity of 40,000#. Here's B&M universal cooler stacked plate design. 29.2K is the bottom (their biggest).
http://www.bmracing.com/PRODUCTS/Universal-SuperCoolers
Old 05-10-2010, 05:41 PM
HoveyBayou's Avatar
You only have to overheat it once to damage the transmission. Do you have a transmission temperature guage? If you are going to risk it for a few weeks at least have one of those. When I got my guage I was quite surprised at what my temperatures were, why GM didn't include a trans temp guage on the half ton 99-06 trucks is beyond me, my truck didn't even have an aux. cooler and was way under-cooled in stock form.
Old 05-10-2010, 08:31 PM
PT's Slowest Truck
budhayes3's Avatar
Tom, those are the brackets that I bought...same price and everything, only from a different member on silvyss.com...I'm confused...
Quick Reply: do i really need a trans cooler??
