doing some work on an 01 silverado, fuel pump and rear end questions
Banned
true, we have pull through parking at my job, and i usually park out further so i don't have to turn very hard either. it wouldn't be to bad for this truck, it's gonna be used for towing mroe than anything i bet.
14 Second Truck Club
Originally Posted by A3Z28
oh yeah, on these truck are the axles 28 or 30 spline? i'm guessing 28, $149 for a spool and $135 for gears is a lot better for a rear diff. to me then $350-400 for a posi and the same for gears. i'll need to find a girdle also...
Edit- The Strange spool would have the large hub diameter. I do not know about the Richmond for sure, but I could find out. The cheaper ones would probably have the stock hub diameter, which wouldnt work.
Cuz I AM a BADMOFO
Adkoonerstrator
Originally Posted by BADMOFO
I'd be leary of "....towing more than anything" with a 3600 converter, unless you're towing a landscaping trailer or something small like that. Towing a car on a regular basis with a 3600 converter is gonna make for high trans. temps and ultimately a dead 4L6xe.
![Grin](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_grin.gif)
Moderator / Sponsor
I run 8.5" internals in the rear in lieu of the 8.6 ... at the time i did my install 8.5" parts were just more readily available. The locker is much nicer that a spool ... spool is goign to wreck things on the street unless you have some seriously low traction crap *** tires.
5.3lSilverado
25
08-29-2016 12:48 AM
