doing some work on an 01 silverado, fuel pump and rear end questions
Old 04-09-2005, 06:38 PM
Adkoonerstrator
XLR8NSS's Avatar
I'm in and out of too many tight *** parking lots and parking garages during the day to think about a spool. My tires would hate me.
Old 04-09-2005, 06:46 PM
Banned
A3Z28's Avatar
true, we have pull through parking at my job, and i usually park out further so i don't have to turn very hard either. it wouldn't be to bad for this truck, it's gonna be used for towing mroe than anything i bet.
Old 04-09-2005, 07:30 PM
14 Second Truck Club
Originally Posted by A3Z28
oh yeah, on these truck are the axles 28 or 30 spline? i'm guessing 28, $149 for a spool and $135 for gears is a lot better for a rear diff. to me then $350-400 for a posi and the same for gears. i'll need to find a girdle also...
Add another few hundred(usually 250-300 retail) for c-clip eliminators also. Also, most of the spools are made for the small hub diameter, so make sure the one you order has the large (99-up) hub diameter, otherwise you cant use it. They do make some with the large, so they are out there. You will know it has the large hub if it requires special bearings for the 98-down rears.
Edit- The Strange spool would have the large hub diameter. I do not know about the Richmond for sure, but I could find out. The cheaper ones would probably have the stock hub diameter, which wouldnt work.
Old 04-09-2005, 11:30 PM
Cuz I AM a BADMOFO
BADMOFO's Avatar
I'd be leary of "....towing more than anything" with a 3600 converter, unless you're towing a landscaping trailer or something small like that. Towing a car on a regular basis with a 3600 converter is gonna make for high trans. temps and ultimately a dead 4L6xe.
Old 04-10-2005, 02:06 PM
Adkoonerstrator
XLR8NSS's Avatar
Good catch.
Old 04-10-2005, 02:23 PM
Moderator / Sponsor
oxidizr's Avatar
Agreed ... My PI 3600 is comng out for a more friendly 2800-3000 for some towing duty.
I run 8.5" internals in the rear in lieu of the 8.6 ... at the time i did my install 8.5" parts were just more readily available. The locker is much nicer that a spool ... spool is goign to wreck things on the street unless you have some seriously low traction crap *** tires.
5.3lSilverado
25
08-29-2016 12:48 AM
pjb1972
09-17-2015 02:06 PM
Oobray
08-12-2015 10:56 AM
Ketis
07-23-2015 12:37 PM
6.Slow06
07-07-2015 09:19 PM
Quick Reply: doing some work on an 01 silverado, fuel pump and rear end questions
