drivers door lock actuator
Old 03-10-2008 | 10:54 PM
budhayes3's Avatar
PT's Slowest Truck
Sounds like something in the mechanism either broke or came undone then, possibly a little arm or something, replacing the assembly would cure that, or you could pull it out first and take a look.
Old 03-10-2008 | 11:15 PM
terravast4's Avatar
I know when I replaced my door handles I was shocked that those parts are held togheter by tiny "plastic" clips. I bet the lever that is attached to the auto door locks has come loose
Old 03-10-2008 | 11:45 PM
LowBlack99's Avatar
Check the clips? You said you had the panel off maybe by accident one of the lock rod got knocked loose? There are 2, one for the key and one for the actuator. Also check to make sure the indicator inside is hooked to the rod as well? If not it could bind and make the door not unlock.
Old 03-11-2008 | 08:38 AM
budhayes3's Avatar
PT's Slowest Truck
That would be alot cheaper than replacing the assembly too
Old 03-11-2008 | 01:08 PM
venomhp's Avatar
well when I had the panel off all of the rods looked as if they were fine, nothing was loose. I couldnt actually see where it was connected to but I tried to jiggle them to see if one was loose and everything seemed fine. Do I need to take off the 3 screws and pull the assembly out to look at it or where exactly is that clip for the actuator? Pics would also help if anyone has some!
Old 03-11-2008 | 02:05 PM
budhayes3's Avatar
PT's Slowest Truck
IIRC, I unbolted mine when I tested my courtesy switch since it gave me more room to work. Removing it probably would be the easiest way to examine the actuator and it's linkage.
Hopefully someone has some pics...now I wish I would have saved mine instead of chucking it...
Old 03-13-2008 | 06:31 PM
venomhp's Avatar
alrighty problem solved...took out the old one to look at it, the arm that pushed it locked or unlocked was broken off (plastic piece) so I slapped it back together, went to the stealership and bought a new one...179.00 Thanks for your help guys
Idryfly5
09-02-2022 09:55 PM
rumblebox
10-29-2015 11:35 AM
the owl
09-04-2015 05:09 PM
SWINGRRRR
09-03-2015 08:49 PM
Quick Reply: drivers door lock actuator
