DRL Mod..take it a little farther?
The DRL mod w/ the turn signals...anyway to make them sequence?...like the old Shelby tailights/signals?....jus curious....
Mine do
All you have to do is cut the hot wire to the DRL and install a relay that is normally closed in it. For your trigger wire to the relay, jump it off of you turn signal hot wire. When the turn signal flashes it will kill the power to your DRL and therefore wig-wag between the DRL and the Turn signal. It look pretty cool.
Now, that will only work when your head lights are off. If you want it to work all of the time wire your DRL's full time. Then they won't go off when your headlights come on.
There are a lot of the guy's on the Avalanche boards that have done this mod. AV's with cladding have a slightly different front end but the wiring is the same.
I dunno...I meant when you hit the turn signal....the drl comes on...stays on..then the actual turn signal comes on..and they both go off...ya know like a sequence....?
Your going to need a specific type of relay for that one.
You will definately have to do some cutting of the wire harnesses for that. Dont think I really recommend it unless your really stuck on it.
Jim
Jim
I figured it would be pretty trick....and it would probly look better it it was more than 2 lights...the Shelby's had i think 3 in a sequence....and the cougers...but jus 2 lights..i dunno..im gonna do the original DRL idea..i think it looks sweet...thanks for enlightening me on that 1Slow....but no..i wasnt dead set on the whole sequnce thing..just an idea.....Thanks again
lycominghunter
08-15-2015 12:26 PM
MileHighSierra
07-06-2015 02:41 AM
thunder550
06-24-2005 09:25 AM
