dual battery setup?
im plan on leaving it hooked to the powerpanel, that the alt/battery run to. ive had it on there for about 5 years, no probs. its the little redbox on the on the right side of the engine
I hooked the Stereo system up to the passenger side battery. That way in theory it is an electrical shock absorber kinda. It also promotes more even charging of the battery theoretically since it is not a coaster battery. But when you do all of this. UPGRADE all of the MAIN power cables. Go to a 0/0 from the alternator directly to the battery I ran individual 0/0 cables from the alternator to each battery, go to a #2 from the battery to the main fuse distribution block assembly. I used optimas so I left the OEM ground cable and did a 0/0 from the battery to block and block to frame for both batterys, I also went to a #2 from the block to firewall.
I went to a welding supply house and used welding cable in the above sizes and then crimped and soldered the eye terminals for a bullet proof connection.
This delivers a charging system that holds 14.4 rock solid and no more headlights that look like a disco ball when you got the beat cranked up.
Depending on the size and number of amps you could need a bigger alternator as well
EDIT if you are a 99' you definitely need more alternator 105 is all you have if you are on the stocker. Install a 2002 escalade or denali alternator they are rated for 145 amps but be careful if you buy parts store crap because they very seldom put out the rated amperage.
thanks for the info 01WS6, the cable upgrade is a great idea. we have all the cable and ends i need at work, so thatll help.yeah mine has the 105 amp, i talked to our Alt/starter tech the other day, he said he would give me a new 145 amp with a lifetime warranty for 150.im curious as to how everythings going to work with my underdrive pulley and overdrive pulley i have , to put on with the new fans as well.
great thread! Anyone have the RPO code for snowplow 2000 Silverados? I need the pass side battery tray for my setup...seems like we all are doing the same mods haha...my stereo is done, but Ive got E-Fans sitting in the garage-don't think my current electrical system will support all of it.
hartinclay
08-03-2015 07:03 PM
