e-fans
e-fans
I've searched and can't find what i'm looking for. Most threads are about upgrading pre 06 trucks. I have an 06 1500hd with the 6.0. What would it take to ditch the clucth fan? I have Hp Tuners so programming is a nonissue. Is it plug and play, with just the harness and relays? Or does the pcm need to be pinned? Can I just order everything needed, such as fans, harness, etc. from GM for an 06?
Any help would be much appreciated!
I though your truck would already have fans but since it's a 1500hd I guess not. All you need is a 05+ GM fan from a 1500 and a harness that gets pinned into you PCM. You can either make your own harness from the 05+ GM wiring diagram or buy one(like stated above).
lycominghunter
26
09-25-2015 07:50 AM
