electric fan problems on 06 5.3 silverado
ive got an 06 5.3 silverado.. i noticed the other day about 5-10 seconds after the initial start up the cooling fans kick on, and after riding the truck 30mins and stopping 45 mins and stopping and so forth, the fans r still running and to the best of my knowledge never kicked off. they run a 160 180 190 no matter the temperature.. i can cut the truck off, start it back and once again the fans continue to run, and i forgot to mention the defrost nor a/c was on.. i dont know if it could be a relay, sensor, and what, and im not sure where the relays and stuff r located to check them, and the truck isnt throwing and codes or anything.. thanks alot for the help guys..
so sorry for the late reply, and yes im talking about the factory electric fans.. they come on right about 5 secs or so after start up and run consecutivley.. but the engine is not throwing and lights nor codes.. and i cant find where the fan relays are located.. they arent in the fuse block in the truck or in the fuse block under the hood where the a/c comp relay starer relay and all the fog lamp relays etc r located.. ttt
While your at it, could you pull that fan relay/fuse block out and take a picture of how it fits/snaps in there? I'm looking at getting it to put in my '02 and want to know if it will fit with what I have:
