Electrical Nightmare!!!
Ok, I need some professional opinions here... I have an 05 silverado that I'm taking parts off of to install on my 2000 sierra. I have takin the e-fans and radiator, and was wondering if it would be feasable to try and remove just the wiring harness for the fans since it is semi-seperate. Or would I be better off just making my own???
Its Pins 42 and 33. Look for a auxiliary fuse/relay box under the hood, I think it contains the relays for the fans. But as stated above you have a 2000 which can only use one pin (from what I've heard). If I were you I would get the fan relay box(for the stock look) and build a harness around it.
What i did.... i took the radiator and Efans out of a 05 and cut the 2 connectors off.. Then wired the connectors to my homemade Efan Harness.
A harness is easy to make.
Ok, the truck I have is a 2000 GMC V6, I have a 2004 5.3 from a tahoe with harness to swap over. I already just cut the connectors and grabbed the relay box. I didn't feel like goin thru the harness to trace down 8 wires. I do need a wiring diagram so I can try to utilize the stock functions for the fans. I am trying to make the truck appear as "stock" as possible. Another ? I have, is how difficult is it to remove the OEM pwr windows and locks from an 05 and install them into the 2000?? Any help would be great!
drummer0415
11
10-24-2015 08:16 PM
kalikid06
09-20-2015 07:46 PM
Alvin@PCMofNC
09-03-2015 06:38 AM
