Emergency brake adjustment for 02-Yukon
Does anyone know how I can adjust the E-brake on a 02-4wd Yukon? My moms truck failed inspection today because it won't hold the truck in drive. It has 4-wheel disc brakes also. Thanks.
remove rear wheels, calipers, and rotors. You will more than likely need to replace them. There is a clip bolted to the housing inside of the ebrke shoe. Unbolt it and remove shoe, install new shoe. install new clip and bolt. use a screwdriver to turn the star wheel on shoe adjuster. Slide rotor on and off to check for fitment. all you need is just a little drag not much.
also you need to look at the insid eof the rotor to check for scarring and such
KINGCYCLES
10-02-2015 10:21 AM
