escalade cluster!!!!!!!!!!!!!
Old 01-12-2006 | 09:06 PM
BillnLA's Avatar
You should not have to calibrate for the difference on the speedometer. The gauge on the left bottom of the cluster is for transmission temperature. It will work when you install the cluster, the sensor and wiring are already there on most GM products. Most are plug and play, but there are some things you have to get done. You should get the cluster flashed with your mileage (and engine hours if you have that currently). This will keep you legal for the odometer. Also, if you have steering wheel radio controls or DIC functions, you will need your VIN flashed to make that work. Clusters are the same for 99-02, then changed in 2003 thru 2005. I'm not sure about the 2006's. There are some differences between each years information functions. Some years provide instant MPG in the DIC and others provide average MPG. If any of this sounds wrong, someone speak up and correct it.
ap2002's Avatar
Originally Posted by dry_kill
What the hell I'm asking is do they have to calibrate for the MPH cuz my speedometer goes up to 100mph and the esky cluster goes up to 120mph, I don't know if it will throw it off or not, that's what is being asked, also i got another question, what is the gauge that is on the bottom left of the cluster? I dont have that gauge on my truck so i was just wondering what it was, and also will that certain gauge work on my truck?
like I said before, NO CALIBRATION is needed!! just plug and play.... the other gauge on is the tranny temp gauge.... which is real nice to have!!
the only calibration needed is the mileage...
Old 01-12-2006 | 10:15 PM
4.8 Liter Of Cola's Avatar
whats to stop someone from lying about the mileage when its reflashed?
Old 01-12-2006 | 10:37 PM
SnakeOiler's Avatar
Listen to this man.
Old 01-12-2006 | 10:49 PM
dry_kill's Avatar
alright sounds good, only bad thing, my odemeter went out about 2 months ago, it went out at about 80,000 miles, not too sure what its at now, i wonder if they can still find it out or not
Old 01-13-2006 | 12:59 PM
RoninsDenali's Avatar
From what i understand the vehicles mileage is also stored in the Brake Control Computer as well as the cluster. But im just repeating what i heard and cannot personally verify this. Perhaps someone else has heard the same? GM Techs?
Old 01-13-2006 | 05:14 PM
02BlueStepside's Avatar
When I took mine to get programmed for the mileage, they wanted to know where I was getting the number. I told them from my original cluster and they went out to look at it.
I have heard it is also stored in something else. I thought I remember hearing the BCM. Most clusters, when you buy new, include a decal that goes in the door jamb that has the mileage when the cluster was changed. However, I would just have it programmed in since it is only like $40, or atleast it was when mine was done.
Old 01-16-2006 | 12:54 PM
Originally Posted by Formulated
Do the Escalade clusters also plug and play into a V6 silverado?
Good question call JP Custom they should know, that is where I got mine from.
cheyenne383
11-13-2015 10:24 AM
Wolftrk99
10-02-2015 09:17 AM
BCraven1018
10-01-2015 09:22 PM
zblee
09-17-2015 08:58 AM
silver-mod-o
09-07-2015 11:22 PM
