Ethanol ?
There are some added tables and some changed parts on the flex fuel vehicles, the octane equivalent for ethanol is like using 110 so running as much timing as you want shouldnt be a problem. I do think other things like the amount of time it takes to evaporate and after start enrichment are changed when running e85 Im shure there is more.
Ive wondered about the differences myself, if you look at a flex fuel pcm vs a regular one you'll see what Im talking about.
Well then, whats the difference in Ethanol and E85? So is it just timing and other calaborations in the computer or is it a "special" part they through in that makes it work?
E85 is 85% ethanol and 15% gas and has an octane rating of about 105. Flex fuel truck have bigger fuel pumps, injectors and a sensor that can measure the ethanol content in the fuel so the PCM can adjust the fuel tables accordinly. Vehicles running on E85 typically get about 2-4 MPG less but its cheaper.
Gas in the mid west has had 10% ethanol in it for years, my truck runs on it just fine, only slightly less MPG. E85 has only come about the last couple of years.
normal trucks without flew fuel may not be able to run e85 also, everything can run 10% ethanol, it wil be a little while before we switch to e85 because of all the older vehicle that cant
suddenurge
02-16-2012 12:06 PM
