EWP ( electric water pump ) measurements and pics
this is the meziere LS1 electric water pump:
for those that are interested, heres some pics with proper measurements and what had to be modded to make the EWP ( car style ) water pump work. sorry a couple pics didnt show the size on the scale i'll name each size per picture. you will need 4 water pump gaskets since theres 2 spacers the idler bolt is metric & water pump bolts are also metric, though i name the bolt length in standard size. all bolts are the same diameter as your stock bolts just need longer ones, meziere supplies the water pump bolts.i got my idler bolt from work
water pump spacers, need 2 = 1/2" thick, a decent machinist can copy off a water pump gasket
idler pulley spacer need 1 = 15/16th's long, 7/16s ( whatever metric is? ) CBH, 1 1/8th ? OSD ( didnt measure it sorry) you can go off your idler bushing
idler bolt = 6" long ( inside cap ) hex head cap screw, diameter, same size as the alt. bracket bolt
how i modified the alt/pwr bracket : i would have put it next to a bracket that was uncut, but i didnt take it out the truck
random pics of the EWP installed :
for what its worth enjoy!!
i do apoligize that it isnt a full detailed write up
if you want a more thorough write up ( how to ) visit here:
http://www.ls1howto.com/index.php?article=26
even shows a 7 rwhp gain
mine to, it keeps the engine really cool even down here in the southeast, its pricey but well worth it.. i actually followed your build which helped make the decission on the EWP
yes, plus with car intake you have to modifiy the truck alt. bracket which takes out the part where the pulley actually resided at.
Tin Foil Hat Wearin' Fool
I wanted an EWP because a lot of guys on Tech have reported decent gains in mileage, the hp it gives is a plus for me and I also got it for a decent price used. Ive searched for months and months on tech and missed out on multiple 350 and 375 sale prices
I also like the fact that you can rig up a manual switch to turn on the EWP and your efans and really cool your truck down quick while sitting still.
IDK what the claimed gains are but there are a few dynos floating around that show 7-8rwhp. Definitely not a big bang for the buck hp wise but if it gives me a little better mileage Ill call it worth it since I didnt spend the 600 for one new.
Im looking to make the most power with the least amount of boost since I tend to be heavy on the skinny peddle Id like to have my power with a long lasting motor. Been trying to snag a gz pump off tech but those go as fast as the EWPs do
GXPJAY
02-13-2022 08:15 AM
05GMC4.8
08-07-2015 09:55 PM
