finding TDC
finding TDC
i finally got the heads and valley cover on without breaking anything. now for the pushrods and rockers. ive read in my haynes manual that the #1 piston needs to be at TDC to torque in. 1345 ex. 1278. rotate 360 degrees torque in.2678 ex. 3456. i cant afford a piston stop and degree wheel. so im going to have employ the screwdriver method. ive never done this, so how do i know when #1's at TDC using the screwdriver.does it need to be on the compression stroke,if so how can i tell that, and whats the effect of rotating the crankshaft 360 degrees...
replies appreciated
replies appreciated
Baltimore Whore
Its pretty simple to just look and see TDC. Rotate the engine over untill you see number 1 coming up. once it is up, move it back and forth, you will be able to tell where TDC is.. It is going to stop, then start back down.. Find the happy spot..
Baltimore Whore
^^^ Correct.. I did not use this method either, as they are self adjusting lifters.. Tq them to 22 ft lb and roll with it.. I did however crank the engine over some, then go back over things..
You just don't want to tighten a rocker down when the pushrod is all the way up because it makes it easier to rip the threads out. I have done it before though and nothing bad happened.
