Fire extinguisher
Old 02-19-2012, 04:42 AM
kr1s's Avatar
Default Fire extinguisher
Whats a good F.E To carry in the vehicle?
Old 02-19-2012, 01:43 PM
lowered907's Avatar
2.5 pound ABC buy one with a metal head. plastic heads suck. A fire company should be able to provide you an extinguisher from Kidde.
Old 02-19-2012, 01:52 PM
JoeyGC5's Avatar
In all my play vehicles I run an AFSS foam suppression systems and backup is a Kiddie 2.5 ABC type bottle I got from the local auto parts store. I've seen cars burn to the ground before and I'd rather have a 5lb supression system and a backup bottle than watch my hard work destroyed.
Old 02-19-2012, 01:53 PM
lowered907's Avatar
Suppression systems are a great way to protect your investment.
Old 02-20-2012, 12:02 AM
kr1s's Avatar
Something like this?
Safecraft LT5AAB - Safecraft LT Series Fire Protection Systems - Overview - SummitRacing.com
How exactly does it work?
Old 02-20-2012, 12:50 AM
lowered907's Avatar
Mount in vehicle. plumb system piping and pull cable. when fire breaks out pull red handle. suppression release and puts out fire. looks like that setup is Halon.
Old 02-20-2012, 08:28 AM
JoeyGC5's Avatar
I run the foam style systems but same principle. You position nozzles around motor, fuel cell, and driver compartment. If fire occurs pull release handle which then opens the valve and the nozzles direct the halon (or foam suppression) to the areas preventing flame outspread.
Old 02-20-2012, 08:38 AM
ak2007r6's Avatar
Surprised that system is Halon. I work in the Oil Field industry and they have a similar setup (only on a large scale) for their facilities up here. Last I heard they are not manufacturing Halon anymore. Just a warning though if you pull it get out of the car as quickly as you can. Halon works by removing all the oxygen from the air....
Old 02-20-2012, 11:12 AM
lowered907's Avatar
Halon is getting more expensive and the EPA does not like it but you can still get it for a price. It won't suffocate you, Halon was made for occupied hazards. But the chemical it's made from when changed by extinguishing fire can be harmful. Most design concentrations allow you to breath and escape situation in a non panic mode.
Old 02-20-2012, 11:34 AM
charcoal03silvy's Avatar
Halon's put a hole in the ozone. The long chemical chain is broken, and when the chain is mixed with gasses from the fire it can be harmful to someone who inhales it.
an ABC dry chem extinguisher would be easiest to keep around
Quick Reply: Fire extinguisher
