flame thrower exhaust system
Tribe Shaman
so i can take it that no one has done one yet.
supercharger, 42lbs injectors, bigger lsa on the cam, got to be some left over vapers in their to burn and make a very nice flame out the tail pipes.
i'll pick up a kit and see what it will do on our trucks.
It's hard to do a flamethrower exhaust with a fuel injected truck,it's just that they can't be easily adjusted to have raw fuel in the tailpipe to be ignited by a spark plug in the pipe.With a carb you can pump the gas with the ignition off to flood the truck to the point that raw fuel is in the tailpipe hit a secondary ignition and boom flames out the exhaust.
Tribe Shaman
you can't tell me that every bit of fuel is burnt from our after market systems.
42lbs injectors to spray more fuel, colder setting on plugs, forced induction,
i don't think the cats get the rest, must be something left to burn, if so then it should make a nice flame leaving a ricer behind.
Tribe Shaman
i have been readding about putting in a propane shot just after the mufflers and about a foot before the plug, this set up should make a 6 foot flame,
freak out some ricers leaving them behind with a little flame show.
Originally Posted by Stroker 1500
i would be afraid to inject propane or nitrous into my exhaust and then spark it... can we say explosion
Originally Posted by maximumrebel1
I've seen a propane setup like that on a tractor. I would say propane would be safer than nitrous but I would consult with someone who has done this before for sure.
![Rolleyes](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/rolleyes.gif)
