Fog lights coming on with the headlights mod
Originally Posted by BadAssChevy327
well everyones on the light thing i thought this might be informal and on topic . if you have a 99 to 02 if you push the dome override button a couple times it shuts the drls off
I found that out while doing about 90-95 MPH one night I was on a deserted highway that had no lights about 11PM. I turned the light on quick to see something and then for some reason I hit it twice to turn it off. If you throught you heard something scream "oh sh*t" on an April night about 2 years ago that was me!
PT's Slowest Truck
Only on 00-02, doesn't work on 99's....(nothing works on 99's...different cam, different injectors, different tuning.... )
In '99 there WAS a bigger difference between the 4.8/5.3 and the 6.0 than in later years.....except for the crank most everything on the '99/'00 6.0's is pretty much the same as '01+ so look for those parts to swap out
PT's Slowest Truck
Originally Posted by Yelo
'99's are just more of a challenge....and that makes it much more satisfying when you DO get something to work right on them
I took care of this mod last night ('05 Sierra). Only takes a few minutes to take the 2 screws off the panel to get under the dash, insert the diode, turn the lights on to make sure it's all good and then put the panel back.
Only problem I have now is that I've gone crazy cleaning the truck over the last few days. Now it is to clean to drive! I'll bite the bullet and get it dirty tomorrow. At least the roads are fairly clean up here now.
One day......one day.
Originally Posted by 04BlackSilverado
Your Welcome
I first set it up for the fogs to come on with the low beams. Did this after I installed the 6000k HIDs in the lows. I didn't like the yellow light from the highs when I turned them on so they got the same HIDs and I also set it up so the lows and fog lights would stay on with the high beams. Yup... it's just like daytime when all of those lights are on!!! Now I just have to wait for an H-10 HID to come out to take care of those too.
The diode upgrade only take a few minutes and some pocket change to do. One of the girls at work saw how bright the truck was tonight. At first she said something about me driving one of those annoying cars that blind her but I did get her to admit that they look good
