Fuel level sensor, what the dealership told me...
Old 11-06-2008, 11:35 AM
CHEVRACER83's Avatar
Originally Posted by TX Tahoe Z71
How hard would the sensor be to replace in a tahoe? I assume I have to drop the tank down since I have no bed to lift off to access it.
yeah you would have to drop teh tank.... but it shouldnt be that bad
Old 11-07-2008, 12:37 PM
desTRUCKtive's Avatar
So my fuel gauge reads 3/4 tank after every time I fill up... not a big deal to me. But I put my truck in for the gauges to be replaced under the GM warranty and asked them to check out the issues with the gas gauge.
Here is what I was told:
"The fuel level sensor is going bad, and when it finally shorts out, it is going to take out the fuel module and fuel pump with it, another $680 to repair."
Is there any truth to this? ...because I don't really care if my gas gauge is exact since I rely only my trip meter, but if it is going to mess things up later, I guess I have to replace it.
If it is under warranty then why don't you just have them replace it?
Old 11-07-2008, 12:39 PM
TX Tahoe Z71's Avatar
I would... but it is no longer under warranty But that just means I can put a cam in and not have to worry about voiding anything
Old 11-14-2008, 02:32 PM
10 Second Club
ForcedInduction's Avatar
this is prolly just the service advisor not understanding what the tech said. or the tech is an idiot.
Advisors never listen....
Old 11-15-2008, 09:36 AM
venomhp's Avatar
my guage has been messed up for almost 3 years, pump is still working, Im replacing it though so my wife doesnt run out of gas in it again...
Old 11-17-2008, 07:53 AM
The failure of the fuel lever sensor is commonplace here with GM. The Engineers claim it to tbe a build up of carbon and other additives in the gasoline, and that it will cause the fuel level sensor to stick. It's basically a resistance potentiometer with a float arm. But the GM Technical Bulletin reccomends the usage of a Fuel System Treatment. The GM Part number on the Treatment is 88861011. The treatment DOES contain Teflon. So the Teflon coats the sensor and keeps it working properly.
While I have had some sucess in resurecting failed fuel level sensors with this treatment, the pass/fail rating is about 60/40.
Old 11-17-2008, 08:16 AM
Where's the Beef?
viciousknid's Avatar
So rather than admiting its a faulty part. They blame the fuel for causing the part to fail. When the part is designed to operate in said fuel.
Old 11-17-2008, 08:36 AM
Moderately Differentiated
dewmanshu's Avatar
That's the name of the game! The blame game.
Old 11-17-2008, 09:04 AM
Thanks, I'll pick some up and run it through. I'll post up the results... if any, afterwards.
Old 11-17-2008, 10:48 AM
lol...well yeah...they aren't going to Cowboy up and say..."hey, we f'd up and made a shitty part". For some reason they can't over-engineer the part to withstand years of being submersed in carbon ricg fuel that will "gum-up" after awhile.
I know what you mean though.....I think I can design better parts than some that are out there, but I still have to say there are alot more benefits to using OEM parts over the aftermarket.....in most cases.
I mean...you know of course that if me and Dewmansu "Dewy" sat around a table with a supply of cold Corona, and got paid to design parts.......then our **** would never break....lol....!!!!!
Quick Reply: Fuel level sensor, what the dealership told me...
