Fuel lines for a 5.3
Old 06-06-2011 | 05:09 PM
silverado-lover's Avatar
Default Fuel lines for a 5.3
I'm doing a 5.3 swap and looking for fuel hoses but I keep reading to use hose rated for at least 60 PSI and I can only find hose rated to 50 PSI or rated for 250 PSI and costs 90 bucks.
So does anyone have a part # or link for some fuel lines that will work?
Old 06-06-2011 | 05:25 PM
black04's Avatar
Stainless braided line should be good but yeah its expensive.
Old 06-06-2011 | 05:33 PM
I've only seen people use rubber lines...I wanna know where they got some that can handle the pressure
Old 06-06-2011 | 05:38 PM
Beatdown Z's Avatar
Laid Back
Fuel Injection line at the parts store should be rated to higher than 50 psi...
Old 06-06-2011 | 06:03 PM
That's too easy
Shittttttttttttttttttt I just checked oriellys and it's $9/ foot
Old 06-06-2011 | 06:07 PM
black04's Avatar
Can you not buy some adapters to use your stock fuel lines? I know they make them for the 96+ vortec 5.7s
Old 06-06-2011 | 06:22 PM
I could use my stock lines if the fuel rail was had a return and feed but since it's just the feed line it won't work.
I found this
https://www.napaonline.com/Catalog/C...006447045&An=0
Old 06-06-2011 | 06:37 PM
offroadrider12's Avatar
just put a carb on, then you only need line rated to 10psi.
Old 06-06-2011 | 08:01 PM
I could use surgical tubing
Old 06-06-2011 | 09:44 PM
black04's Avatar
I wouldnt use rubber hose. I know here if you have over 12" of rubber in your fuel line then they wont pass safety.
5.3Okasai
03-09-2022 01:07 PM
chopperloco
07-10-2016 10:45 PM
MWRitter
07-27-2015 09:41 AM
76k10chase
07-17-2015 01:48 PM
Nimoryan
07-05-2015 03:50 PM
Quick Reply: Fuel lines for a 5.3
