fuel pump difference between 99-03 to 04+
Old 03-19-2012 | 12:15 AM
TheRepairMan's Avatar
Banned
Default fuel pump difference between 99-03 to 04+
i know the earlier models were return style and then they went to return less..i bought a fuel cell from a member on here and it was made for the stock fuel bucket to drop right in..well when it was on his truck it work his stock one slid right in...well with my fuel bucket theres no way in hell its going to fit..so did the size of the buckets change over the years?
Old 03-19-2012 | 12:27 AM
Atomic's Avatar
I have a gauge for that
Yes. The 99-03 buckets are much smaller than the 04+ buckets.
Old 03-19-2012 | 12:43 AM
Banned
0hhhhh boy ! well how hard is it to make a older pump work in the newer truck
Old 03-19-2012 | 12:48 AM
Atomic's Avatar
Very hard considering how the bucket seals and locks into the tank...
you could always buy an older tank and throw it in, the mounting locations are the same. For instance, I am using a tank from a NNBS 08 truck in my 99 and using an 04 fuel bucket...
Old 03-19-2012 | 12:50 AM
Banned
im using a fuel cell built by db rods..but it was build for the older pump and i have a newer truck
Old 03-19-2012 | 12:51 AM
Banned
are they plug and play? as for connectors and wiring
Old 03-19-2012 | 01:03 AM
Atomic's Avatar
Not really...the wiring harness needs wires moved around, the 4 pin one on top. I think the evap connectors are different also.
My suggestion is to resell the tank (or see if he will take it back) and get one that fits yours.
Old 03-19-2012 | 07:58 AM
Banned
selling isnt an option lol. i plan on running a inline fuel pump, but i was really just wanting to use the fuel bucket for the gas gauge. '
what do i have to do to make this work?
Old 03-19-2012 | 09:13 AM
Atomic's Avatar
You have a problem there too since GM changed the gauge between the years...you need to switch some wires on the harness and potentially resolder the leads on the float resistor.
Old 03-19-2012 | 01:58 PM
Banned
**** my life
slowlsx
08-13-2015 09:28 PM
05GMC4.8
08-07-2015 10:55 PM
MS3Z
07-30-2015 07:17 PM
InsaneDomestics
07-27-2015 03:42 PM
Mossyoakglock
07-17-2015 09:30 AM
