FYI Cheap Valley cover for Gen 4 DOD Delete
GM part # 12598832 is the Valley cover that is from the early non AFM 6.2 in the Denali truck it does not have the crankcase vent on the front that has to be plugged to use on the NNBS trucks and comes with the gasket to block off all the AFM oil ports and the bolts. GM list is $42.78 for this part. I kept seeing everyone advertising the LS2 for use GM list is $141.53 and you have to block the vent tube off.
No. The LS6 is a Gen3 motor with the knock sensors in the valley. The LS3 or LS7 should have a comperable pcv system to the LS6 though as Coban pointed out. You just plug the valve cover nipple and run the hose from the intake to the valley cover.
