Gas Mileage
Old 01-25-2007, 10:28 PM
  #21
It'llrun's Avatar
Originally Posted by DozerDan
Alot of guys on here with 20's or bigger that have gone with 4.10's claim better mileage simply because the motor doesn't have to lug as much
I get that, but it seems the rpm range would be higher, causing fuel economy to be about equal to what it was because of the larger wheels as opposed to smaller wheels. Once you get rolling, the larger wheels should offset the difference of smaller ones, which would be easier to get rolling in the 1st place. I just think the difference would be negligible unless you're looking to operate in a specific rpm range where economy is best.
Old 01-25-2007, 10:30 PM
  #22
11 Second Club
Phantom's Avatar
they also say these motors are more efficient around 2100rpm...i heard or read that somewhere
Old 01-25-2007, 11:35 PM
  #23
SmokingWS6's Avatar
I have a 4.8 ecsb 4x2 silverado, 3.42 gears. It averages in the 17's with a city/highway mix on a mild to heavy foot. It is capable of 21mpg highway. I've yet to tune it, fuel trims are slightly off so it might gain mpg after a bit of tuning. I'd like to get a stock HD 6.0 y-pipe and catback.
From what i've seen the LSx v8's often get the same or better milage than the 4.3 v6.
Old 01-25-2007, 11:36 PM
  #24
SmokedSierra01's Avatar
With all that header and cam addittion to your truck I would have to see the numbers. Its very hard to specifically tell that you have gotten 2-3 miles per gallon from one thing or another. Many things affect mpg such as weather conditions (hot/cold, cold being more efficient), road conditons(are there any slopes, gradual inclines, etc), what rpm you rev to each shift, etc.... Unless you calculate the exact amount of gas you put into your tank against how many miles you drive exactly, and factor in all driving conditions, the information is not entirely accurrate. Its the same thing as those air filter companies that claim 20hp, when you see about 3-5 at the wheel. When I see a thread on here with a good study on aftermarket parts and their affect on mpg then I will be a believer.
  #25
Turbo-T's Avatar
Old 01-27-2007, 10:38 AM
  #26
Ucantcme57's Avatar
Some of my friends say that I won't be able to pull this 30' out of the water without 4 wheel drive? Is this true? I haven't pulled a boat out in 10 yrs, and it was a 20' with the same type of setup..
Old 01-29-2007, 11:14 AM
  #27
Old 01-29-2007, 09:44 PM
  #28
chevyguy7802's Avatar
I get 17 on my 02 with the 20's other than exhaust its stock
Old 01-30-2007, 10:30 AM
  #29
Made in South Korea
Snacktime's Avatar
If you launch in salt water, 4x4 is required during low tide due to algie.
Old 01-30-2007, 11:24 AM
  #30
Tootall's Avatar
02 ex-cab silverado,4.8, auto
stock tune,stock muff, stock tires on stock 16s
cheep k&n drop in
Trans Go HD2
efans
tires front 35, rear 30-32psi
75-80 on flat road from Brownsville to Houston 24mpg with out cruse, 87 octane
SloSVO
11-22-2020 07:34 PM
bearden86
26
11-15-2015 03:58 PM
turbo6c3
10-05-2015 06:11 PM
redbird555
09-30-2015 09:28 AM
sTNT971
09-26-2015 04:22 PM
Quick Reply: Gas Mileage
