glowshiftdirect Gauge
Old 11-20-2008, 01:55 PM
Go5.3tt06's Avatar
Default glowshiftdirect Gauge
http://www.glowshiftdirect.com/index.aspx
I plan to get there for
Fuel Pressure
Boost/Vac 30 psi
Air/fuel ratio- Is that wideband? If not and show me where wideband look like
Get Dual Aeroforce scan gauges or need one scan? Will going to be on Overhead Console.
Let me know if I miss?
Do you think glowshift gauges worth? I like the colors and lights
Old 11-20-2008, 01:58 PM
RandomHero's Avatar
Those look shitty as hell honestly.
Here's what I run
Wideband-PLX
Fuel Pressure-Autometer
Aerforce Scan gauge for normal functions
I haven't decided what I'm going to run for a boost gauge yet.
I'd stay away from that stuff.
Old 11-20-2008, 02:52 PM
Gordy M's Avatar
One of the problem with the digital gauges is they work only as long as the light wiring last. Some last forever and are fine, some carry a 60 ft or 60 sec warranty (what ever comes first). An analog gauge will not burn out and they are a long term solution if the auxiliary lighting for nite driving burns out you only have to replace a bulb and it works fine. With the digital when they burn out they are toast. HTH
Old 11-20-2008, 02:59 PM
Go5.3tt06's Avatar
Here's what I run
Wideband-PLX
I see wideband plx. But there is to many different. You say not good idea to have glowshift. What other better look?
Old 11-20-2008, 06:23 PM
phasemaster1's Avatar
used search feature look what I found...https://www.performancetrucks.net/fo...d.php?t=423272
Old 11-20-2008, 07:42 PM
Go5.3tt06's Avatar
Thank for yall help. One thing do I need dual or one scan gauge? CHeck http://www.ecrater.com/product.php?pid=3271860.
I cant find forum to tell how to install temp gauge electric wire to tranny?
U think glowshift is same as http://prosportgauges.com/search.asp...fuel+pressure? I like the looks. But I think most ppl not like it. I still want to know about wideband which I go PLX or AEM. I see PLX come with box just plug and play
Old 11-20-2008, 10:26 PM
rockerjoe2008's Avatar
Go with auto meter gauges. If you get an A/F make sure its a wideband.
Here's what mine look like, I really like them at night. Top gauge is a fuel pressurer, middle is boost/vac, bottom is a DPIC just for kicks.
Old 11-21-2008, 09:22 AM
Go5.3tt06's Avatar
rockerjoe2008 - how much did you spend $ on it? Wish I could have black face and needle orange light like match my OEM cluster if not have one. Not big deal. Wideband exactly what I need those http://www.maperformance.com/aem-gau...FRyenAod3A0X-w
Old 11-21-2008, 09:52 AM
The House is Rockin'
BLUES MAN's Avatar
those look awsum man
Old 11-21-2008, 11:30 AM
SpoolinChevy's Avatar
I have the cobalt's also. They aren't too expensive, the wideband is what brings the cost up. IMO, if you're going to do it, get the reputable stuff so you don't have to mess with it. Here's a shot of my Cobalt's.
Quick Reply: glowshiftdirect Gauge
