glowshiftdirect Gauge
rockerjoe2008 - how much did you spend $ on it? Wish I could have black face and needle orange light like match my OEM cluster if not have one. Not big deal. Wideband exactly what I need those http://www.maperformance.com/aem-gau...FRyenAod3A0X-w
![Chug! Chug! Chug!](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_chug.gif)
![Happy](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_stretch.gif)
Hunt&Fisherator
Here's what you need....
Full sweep mechanical boost/vac
Full sweep electric 0-100psi fuel pressure
And the wideband of your choice. I run a innovate LC-1 with XD-16 programmable guage.
I run autometer Phantoms for everything but the wideband,I also have a pyrometer to keep an eye on EGTs, these guages are fairly common and easy to read at a glance.
Could you please search and look around a bit seriously? All this stuff has been covered a ton of times. Just search the show and shine section. Pretty much everything you post is... Sorry if I sound like I'm coming off rude but to build a setup like what you're wanting you have to look around and read up. Everything can't be spoon fed...
Which is a perfect reason to master the art of the Search capability. No one is trying to be rude, but it's not fair to other member that may need help when you have 15 ongoing threads that clutter up the boards. When that happens other people's threads may not be seen.
Also, I agree with Ben. You have some very high hopes it seems for your truck. That's great, but maybe you should start a little smaller since you know very little. 4 years, ago I wouldn't have done what I'm doing to my truck now.
Whoa, nobody is insulting you and threats aren't cool!![The Judge](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_judge.gif)
All anybody is trying to say is that you could have, with out a doubt, found all the info that you have received in this thread by searching other peoples threads. You may not find a discussion that exactly matches your question but you can take the principles you learn and apply them to your needs. People here are eager to help, including RandomHero and Silver-mod-o, just not when the topics have been covered many times.
