GM hybrid gas/electic trucks...
Mod with training wheels
I wouldn't waste my time with those production hybrids. Better get this guy to modify your truck...you won't regret it.
Video: Homebuilt Steaurus 2000 is a Blue Oval the likes of which we've never seen
They are different. They drive different. They are a lot smoother for the most part than a standard ICE vehicle.
For what its design is, it works fairly well.
It would not benefit from a turbo. By design the ICE drives the front drive motor/generator assembly to produce electricity while the rear drive motor/generator assembly drives the prop shafts to move the vehicle. There are 4 possible mechanical forward gears but they are rarely used.
Yes. I'm GM certified to work on them.
There is a time when the ICE does direct drive the rearend. I wouldn't want to put anymore power through them than they have now. They weren't designed for big power. Towing capacity is only 6,000lbs. The trans is a 2ML70. How well are the 4L70s holding up to big power?
LoneSStar
09-28-2015 09:07 AM
iregret
09-07-2015 01:20 PM
