going from syn back to regular, safe?
Old 08-12-2006, 01:52 PM
Big10Fan's Avatar
Default going from syn back to regular, safe?
my last oil change at 24k I put mobil 1 in, and now I really dont care nor have the money to pay for mobil 1 for oil changes from here out. will that 1 time effect anything? is it ok to go back to the regular stuff?
03 4.8
Old 08-12-2006, 02:47 PM
TurboGibbs's Avatar
It was ok to swap from mineral oil to synthetic for that one change wasn't it. Swaping the other direction is no different. Pretty much all oils mix fine now a days.
Old 08-12-2006, 04:21 PM
PT's Slowest Truck
budhayes3's Avatar
You'll be fine, no worries
Old 08-13-2006, 01:00 AM
SBTork's Avatar
yeah, you'll be fine either way. Synthetic is good, but it should not hurt anything to change back to conventional
Old 08-13-2006, 01:16 AM
nonnieselman's Avatar
ive known some people that mix all kinds of oil in motors.
My uncle didnt have any oil that he regularly uses, and he had to get to work. So he got some 75w-90, 20w-40, 10w-30, and some other stuff he had laying around. This was in his 79 chevy 400sb. and for the last 5yrs he just puts what every oil in it he has laying around. He puts this truck in MudBoggs and runs the crap out of it.
My brother mixes 2qts of Lucas Oil Stablizer with 4qts of Castrol GTX in his 77 chevy w/383 stroker. It keeps it pretty dang quiet. Dont know if thats a good thing or not. but its still running after a year.
The Check Engine Oil Level light came on in my truck one day while my mom had it, she just put a quart of some 20w-40 in it. But i changed it the next day with Mobil 1.
So i couldnt see where the change back to Dino oil would hurt.
Old 08-13-2006, 09:39 PM
I've heard that switching off of synthetic to back to conventional could create foaming in the oil.
I have also been told that you can safely switch from synthetic to semi-synthetic.
True or not, I don't know.
My truck and car gets full synthetic and it stays that way.
jim
Old 08-13-2006, 10:42 PM
Big10Fan's Avatar
jim
and if true, foaming does what?
Old 08-14-2006, 12:07 AM
Exclamation
Foam = air????????Hmmmmmmmmmm..... That's what I want my oil pump circulating!!!!! Sit back and think about it first.
Try running hydraulic systems with hydraulic fluid that is foamed because the wrong oil was mixed in. The hydraulic pump looses the ability to create pressure. Therefore, the hydraulic line pressure drops significantly.
Same concept with foaming engine oil and your oil pump.
Jim
Old 08-14-2006, 12:14 AM
Big10Fan's Avatar
k i got 4 saying its ok and 1 saying it may cause foam
Old 08-14-2006, 01:30 AM
Red face
You can do whatever you want. I'm just giving you my opinion.
It's your truck man, not mine.
Jim
Quick Reply: going from syn back to regular, safe?
