Got a problem, NEED HELP
Old 10-28-2005, 10:52 AM
02BigBlock's Avatar
Default Got a problem, NEED HELP
I got home today from school and my truck was in the garage and when I went to start it all the guages went to normal but when I turn the key to the postion to start it everything goes dead and the temp guage pegs 210. Anyone have a similiar problem? what do I do to fix it? Thanks guys
Old 10-28-2005, 11:25 AM
white1's Avatar
Sounds like a bad ground. When did it start, did you change anything, is the trans guage stock,or aftermarket? I'd check and make sure your grounds are all good. Will the truck start?
Old 10-28-2005, 11:27 AM
02BigBlock's Avatar
I checked all the grounds and then I tried and the same dam thing happens. The temp guage pegs 210 and then nothing. All the lights, horn, turn signals everything works like it normaly does then when you turn the key the dam thing goes dead.
Old 10-28-2005, 03:03 PM
white1's Avatar
Try unhooking your trans temp guage and see if it still happens
Old 10-28-2005, 03:10 PM
Need More N2O Mod
mwalls54's Avatar
He isn't talking about a trans temp guage since his truck has a 5 speed.
Old 10-28-2005, 05:15 PM
which truck in the sig are you talking about?????
Old 10-28-2005, 06:49 PM
02BigBlock's Avatar
Its my 1993 C2500, I put it in the garage before school and then when I came home I turned the key and nothing but the temp gauge goes to 210. SO I'm going to jump it in the morning from the positive post on the starter.
Old 10-28-2005, 08:10 PM
cangrick's Avatar
check your starter wires, had that happen with my camaro everything untill i tried to start it.
Old 10-28-2005, 09:39 PM
slammedS10's Avatar
sounds like a bad connection at the starter,
Old 10-29-2005, 03:58 AM
02BigBlock's Avatar
Alright, I couldnt sleep all night because the thing was really making me mad and at 4 this morning I got it running, the nuetral saftey switch was messed up or something becuase all I did was move it around and she started right up. But thank you for your help, I love this site.
Quick Reply: Got a problem, NEED HELP
