Grounding Issues
Grounding Issues
Has anyone had a lot of grounding issues? I have an 04 Suburban, and it's weird...for starters, my rear door lock fuse keeps blowing. I've upped the amps and everything, but it's still happening. Does anyone know where the ground is for that?
In addition, when I put the truck in park, the rear passenger window rolls up, which again sounds to me like a grounding issue. Does anyone have any kind of direction for me?
11 Second Hall Moniter
If it keeps blowing the fuse, then it has a short-circuit. If it had a bad ground, then that creates an intermittent open circuit, which would not ever blow the fuse.
You probably have a bad lock actuator. Of course, check for cracked/chaffed wiring to the actuator first.
The doors are set to unlock shifting into park. Where do I look for this. Hate to sound stupid but electronics have never been my specialty lol/
Then check the harness going to that door. It sounds like the signal to unlock the door is raising the electric window instead. Probably a pinched/melted/rubbed thru wire causing the wires to cross. Has the vehicle ever been in an accident?
You can go thru the info center and change the settings so that the auto lock/unlock feature is disabled if you want to. The owner's manual will show you the specifics on how to do it, if you need. Don't forget to change the settings for both driver #1 and driver #2.
murderedSS
27
10-12-2015 11:13 AM
muncie21
09-07-2015 09:55 PM
