guage cluster OOPS!!
Old 11-19-2006 | 10:32 AM
chevythunder06's Avatar
In the 12's??????
Default guage cluster OOPS!!
I was finished putting in my new deck last night and said what the hell.....Im gonna try and clear my guage needles.
After getting the shell apart I noticed the Tach's needle facing almost all the way down....I Must have damaged the inside of the cluster. No visible damage from the outside.
If I bring it to GM, do you you guys think they would replace it under warranty if it was just misteriously "not working"?
thanks,
Jesse
Old 11-19-2006 | 10:35 AM
Nick™'s Avatar
put it back together and see if it goes back to where it should be. The needles jump around when unplugged from the truck, probably no big deal...
Old 11-19-2006 | 10:38 AM
In the 12's??????
nope, Put it back together last night idles under 0 rpm, and WOT only hits about 2500rpm.
Old 11-19-2006 | 01:27 PM
Grumpy5.3's Avatar
as big of a problem we are having with clusters they would probably not ask too much and just order you one!!!
Old 11-19-2006 | 08:02 PM
04BlackSilverado's Avatar
The needle may be in the wrong spot, Take the needle off and the clear face of the cluster off and plug it in and put the key to run, then push the needle on the shaft in the zero mark and it may be OK.
If its the servo, get the dealer to fix it..... Or if they won't fix it, send it to me and I can replace it for you. I'll just have to make a few phone calls for a new servo, and solder it in.
Old 11-19-2006 | 09:30 PM
In the 12's??????
I'll try the dealer first and see what they have to say or what they can do, if they arent helpful, I'll let you have a go at it steve....I was wanting to talk to you about doing the LED's for the truck anyway.
Thanks
Old 11-21-2006 | 07:02 PM
In the 12's??????
Got an appointment for the truck to go into the dealer tomorrow. Just wanted to ask if anyone knew what theyd have to do as far as reprograming if they did have to replace my cluster. They wont f#*k up my computer will they?? We finally got this thing running right.
I hope its reprograming something other than my PCM
Please let me have some good news!!
Old 11-22-2006 | 12:48 PM
If you get your gauge fixed under warranty, I say strike one for the customer.
I would recommend calling these people (Autocraft Electronics) up and them fix it, oh yeah this is the company that repairs all of GM Cluster gauges. If the dealer has to send your gauge off this is were it will be going.
Old 11-22-2006 | 12:54 PM
In the 12's??????
just got back from the dealer, they ordered me a new cluster. this one is out.
they said all they have to do is put the new one in and reprogram the mileage and engine hours.
Lthompson
10-02-2015 01:45 AM
Lthompson
09-21-2015 08:06 PM
zblee
09-17-2015 08:58 AM
fiatdale
09-11-2015 03:07 PM
andrewlong
09-08-2015 11:25 PM
