Guage cluster replacement
#23
Well there are a lot of things that can be done with a cluster swap. On the GMT800 there is no programming necessary. You can put in a cluster with "0" miles and go. Just beware using the Tech 2 scan tool, I can see mileage on the PCM and BCM. If they do not match the cluster mileage then, well you get the point.......
#24
As for the radio, now you know why you don't see a lot of factory navs around because of the cost. I bought it when I made real money.... Now I would never be able to get one again. Look for them used some of them now go for 400 or so. That was why on my cluster I didn't drive it for one day until the cluster came in and it had the run hours and miles I told them to program on it and you had to sign and fax a form to them certifing the hours and miles.
