HD Grille with non-HD hood
I have searched, and have not been able to find any information on this
If you use the HD grille/06-07(Classic) without the HD hood, is there going to be any interference between the two?
I have an 05 RCSB.
I have an 05 RCSB.
So using the 05 grille with the 05 up HD hood will create a gap.
Will using the 06-07 grille with the standard 05 hood create an overlap of the hood and grille?
Anyone happen to have a picture of this?
Well, no one would ever say exactly why the HD grille would not work, just that it "doesn't".
So I bought one, and yes, it works just fine. I measured both the old and new, and they are the EXACT same dimensions when it comes to the mounting tabs.
The only difference is the older style grille has that curve at the top to match the older style hood, as the newer HD hoods are flat. You can see the gap created in the picture.
